Question about Stihl Garden
Stihl pole saw will not spin when pole is extended. Shaft will not stay out.
  • 486 Answers
You must disassemble the shaft assembly.
**NOTE: take a photo of each step of disassembly so that you will have a record of how to reassemble and where all the pieces go.
I have worked with them for over 20 years, it is hard to remember, and there is no book!
More than likely you have an inner shaft driver or bearing that has failed, the shaft my be excessively worn. It is hard to say without seeing what is inside.
Posted on Jan 23, 2017
  • 22 Answers
SOURCE: looking for a manual for a stihl pole power saw
Your local Stihl dealer can order the manual for you. It might be free or there could be a small charge for shipping. Either way, it's worth having the manual and Stihl WANTS you to have the manual. Be sure to have your model number and serial number with you when you go to the dealer.
Posted on Jun 16, 2009
  • 188 Answers
SOURCE: pole saw lock broken when i extend handle need new lock
I just contacted Master Parts and they have that part available (121560-01). You ca contact them toll free at 800-446-1446 or you can find them online at www.masterparts.net. I hope this helps!
Posted on Jul 20, 2009
  • 4088 Answers
SOURCE: I have a Stihl ht101 pole saw that is not oiling
Remove the bar and chain and run the saw. Does oil come out of the side port? If not, check the pump, lines, and in-tank filter. If ok, clean all the holes in the drive end of the bar including the small holes that pass oil to the chain slot. Compressed air helps here. Clean the chain slot. Oil the chain manually after assembly.
Posted on Sep 12, 2009
  • 193 Answers
SOURCE: Remington pole saw
Problem is most likely in the trigger switch on pole. Bypass switch and test bu plugging lamp into power cord coming from pole
Posted on Jan 10, 2010
treefella72
SOURCE: I have a stihl pole saw ht101. The saw starts fine and runs for a minute or two, then loses power. What ido I check?
If you mean the engine is losing power your more than likely have a restriction in the exhaust. The sut from the two stroke mix builds up and restricts the exhaust gases. Hence looses power. Happened to me lots of times
Posted on Aug 02, 2012
How do you get the drive shaft out of the pole on a stihl 101 pole saw?
Bought brand new! I saved up for this product for awhile since they are pretty pricey. I also own acreage in the Midwest so this tool is much needed. I owe 2 older stihl chainsaws and fs70 trimmer. I work sometimes 70-80 hours a week so anytime I have on the weekends to clean up tree damage from storms, etc is precious.
More details about the best pole saw go to the link The Best Pole Saw In 2018 Practical Overview of Top Pole Saws
May 31, 2017 | Stihl Garden
The unit was not as advertised. Hard to start, runs poorly and won't idle. Had to take it to the local stihl dealership for service.
For best pole saw open the link The Best Pole Saw In 2018 Practical Overview of Top Pole Saws
Mar 20, 2017 | Stihl Garden
STIHL pole saw 101
Hi Little Bird
Chances are that the clutch needs servicing or replacement.
Here's a link that explains:
http://www.lilredbarn.net/Stihl-HT-101-Pole-Pruner-Clutch-s/29554.htm
Cheers
Jun 06, 2016 | Stihl HT101 Pole pruner
My Stihl HT 75 pole pruner pulls the shaft out of the clutch housing when I extend it out. Any suggestions on the problem?
sounds like the drive shafts have been put the tube the wrong way, or something is missing from the inner shaft.. I've attached the breakdown manual so you can check.
http://www.mediafire.com/view/ouuv979oehvbm0w
Mar 31, 2015 | Stihl Garden
Stihl HT75 pole saw
Stihl HT 75 pole saw is great. If you want easy to pruning tree by the best pole saw go to the link The Ultimate Remington Electric Chainsaw Reviews
Jan 18, 2012 | Garden
Garden Logo
290 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
