Question about GE Washing Machines
Load size knob is out of sink with the size of load. everything still works, just the knob won't land on the small, med or large setting.
  • cprimm2 Jul 20, 2009
    Okay, I'm an idiot. You didn't solve my problem, so does that make you an "A-hole" or an idiot too?
  • 3 Answers
Its spelled "Sync" idiot.
Posted on Jul 20, 2009
  • robgdan Jul 20, 2009
    That would make me an A-Hole :)
Roper will run water over top if set to large load
bad conection, not telling when water is at level
Dec 18, 2014 | Roper Washing Machines
Whirlpool GSQ9669LW1 washer. Originally Load Size was set to small. After water was filled to that level and machine started to work, wanted to add more water. Turned the Load Size knob to Medium, nothing...
You would have to start the wash cycle all over in order to get enough water for the med load size. Once the washer starts it cycle you have to cancel that cycle to start a new one. Hope this is a help to your question
Apr 24, 2014 | Whirlpool Washing Machines
The load size knob just spins and doesnt select size of load large medium or small i think its set at medium so i can't set it at large or small
Pull the knob off and look at it. You will probably find that the knob is bad.Hope this fixed your problem.If not the knob then the switch is bad.
Jun 20, 2011 | Washing Machines
Washing Machine wont recoginze the load amount to fill with water, ex..small, med, it justs keep filling up to the brim??
Sounds like your problem is one of three things. Most common is that you have to "reset" the water level. This is done by turning the water level knob passed the large load size, and then down to small. Any time you want to go to a smaller sized load, you have to do this. Another possibility is that the pressure switch is bad, this is an easy fix (although not as easy as the reset) The switch can be purchased thru a local parts supply house. And the last thing could be a bad water valve. This will leak and continue to fill the washer after it is already full, this however is usually followed with water all over the floor. If it is not the reset, write me back and I'll walk you thru the other repairs. Hope this helps!
Dec 08, 2009 | Maytag Performa PAV2200
Won't stop filling, water just keeps running into washer even after agitation starts have to turn water connection off to stop filling
check to make sure the control knobs are turned to exactly small -med -or large - if it's in the middle of say med and large loads the water will over flow - this happened to us three times (cause of daughter!)
Aug 26, 2009 | Washing Machines
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
The washer only fills up full even when I put the load size on sm
Check the other knob or switch on top. Perhaps it has some settings regarding small, medium, or large load. This switch may be defective. Go to
www.repairclinic.com for more help on removal and replacement. You can also order a new one from them.
Mar 14, 2009 | Washing Machines
Timer setting
choose the load size on the timer for what your putting in large small medium etc match the water fill large small med etc select wash rinse temp to you pref add soap bleach fabric softner pull out the knob make sure the lid is closed
Feb 18, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
