Question about Samsung Televison & Video
My Samsung 50 inch TV will not power on no power led. When I plug in the power cable the backlight flickers but TV will not turn on. Would this be a T-Con, power supply or main board issue?
The TV is a Samsung un50h5203afxza version mh01. As stated if I plug in the power cable the backlight flickers about once per second but the red power led will not come on. The TV itself does not respond to the power button on the remote. I checked the power supply board and no caps looked burned out and the mainboard doesn't have any signs of toasting. I tried reseating the cables to see if maybe it was a bad connection but that did not fix the issue. The TV is only about 2 years old so it's out of warranty but the screen is still in good shape.
circuitcity
  • 137 Answers
SOURCE: Samsung 46" LCD TV stops responding
Ok, There are well three boards in this set that would influence such a behavior. The culprit is the Key Pad Board. It has what is called a leaky switch. This then locks up the Microprocessor. This will result in the set operating like a ghost has the remote.
best regards
CircuitCity
Posted on Dec 06, 2007
eagle338
  • 4889 Answers
SOURCE: I have Sharp Aquos LC-65D64U
It sounds like a backlight inverter to me. I am 99% sure. The buzzing noise you mentioned kind of confirms that, so does the backlight turning off. If you want to test them, then you are gonna need a multimeter. I will see if I can find a schematic in my collection, but be aware that this is a highvoltage device we are dealing with. May not be a good idea to test it yourself if you have never worked on electronics before. The sets hold nasty voltages for several days after its turned off and unplugged, and can injure you if you are not careful. I don't mean to scare you but its my job to tell you. If you want to proceed then I'm game.
Posted on Nov 01, 2010
eagle338
  • 4889 Answers
SOURCE: Visio p42hd, no picture
Yes it does sound like the mainboard. But we have to confirm. I will see if there is a service manual for this unit in my collection but do you think you can safely work on it? Have you worked on electronics before? The last thing I want is you hurting yourself trying to fix it. HV circuits are not to be messed with unless you know about them.
Posted on Nov 03, 2010
SOURCE: I got a Sony Bravia
http://www.smpcshop.com/KDL-40WL135-KDL-46WL135-p-8895.html
Above is a link for a service manual.
Hi, well I applaud you for starting in the right place, The power supply, as, if, that isn't right nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" now while that may be true in a few cases, a faulty Electrolytic Cap, or ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
Gee it seems that you have replaced just about the entire "Guts" of the set, in the industry we call this the "Shot gun" method, however it seldom works in reality. One really needs to isolate the Cause, of the "Fault" and repair that and also any damage done by that. As if one doesn't remove the "Cause" it will simply fault again when the "New" bit is connected up. One needs to get the unit going section by section, testing and proving the prior section before connecting up to the next, which also must be tested to make sure that what you are going to connect will NOT damage what you are connecting it to.
Also unfortunately, these LED's Blinks, are NOT an error code in actual fact.
What you need to do is use the service manual, and follow through the troubleshooting steps, to isolate and hopefully repair your problem.
Basically it is all about voltages and if they are correct, a Higher voltage than stated usually means a component is Open circuit or a very high resistance, whereas a Lower than stated voltage usually indicates a Short Circuit, or low value resistance component, is "Faulty". These are all in the SM, as are the waveforms that must be checked, it is indeed very difficult to repair electronics these days without specialised equipment and even though I have over 30 years experience i find it difficult, so good luck.
Posted on Feb 24, 2011
SD Tech
  • 14553 Answers
SOURCE: AKAI LCT37Z6TA TV Issues
Sounds like the main board as it has all control and signal processing on it.
Posted on May 17, 2012
I have a Samsung UN50H5203 LED smart tv that has sound, but no picture.
I wouldn't replace a power board before measuring to see if the voltages are there and correct....
Sep 08, 2016 | Samsung UN50H5203 - 50-Inch Full HD 60Hz...
LED TV - replaced power board but still no backlight? LED backlights do not seem to work.
yes the led backlight for whatever reason is not functioning and that is the root cause of your problem. Unfortunately to find a replacement led backlight is tough as the backlight is normally fixed with the lcd panel and has to match the voltage and all that stuff with motherboard. and if that doesn't match you might short the tv itself. this case is as good as getting a replacement lcd panel.
Feb 17, 2016 | Seiki SE50FY10 50-Inch 1080p 60Hz LED HDTV...
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Samsung un40eh5000f led backlight don't work i replaced power supply and main board still no luck
Troubleshooting the Samsung LED TV Model UN32EH4003 ...
? 2:46
https://www.youtube.com/watch?v=2TImpsUnGtI
Jun 25, 2013 - Uploaded by George Droukas
Samsung TV troubleshooting, In this video you will be able successfully ... where can I buy the power supply board? the ledlight doesn't light up so it .... The second port was still fully intact but also not working, I was able to get it .... which turns onbacklight (BLU_on) and turns on the power supply (PS_on).
Samsung UN40EH5000 Review; 40-inch LED TV, (also ...
reviews.lcdtvbuyingguide.com/samsung-lcd.../samsung-un40eh5000.ht...
The EH5000 is Samsung's lowest end line in the larger size LED backlit LCD TVs for... 60Hz refresh rate doesn't handle judder sports programing and gaming as ... take advantage of the resolution, giving you more work space on the screen.
Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV
www.amazon.com/Samsung-UN40EH5000.../B00723...
Amazon.com, Inc.Samsung UN40EH5000 40-Inch 1080p 60Hz LED TV (2012 Model) ... Samsung didn't advertise this (or maybe its just my TV), but I have absolutely NO BACKLIGHT BLEED...... Hope that helps you find the settings that work best for you. ..... Game Modedoesn't really do anything except make the picture darker and less ...
Jan 05, 2016 | Samsung 40-inch LED TV - UN40EH5000FXZA...
Samsung 50" led tv turns on and off
Does it do this with no cables plugged into it? If it does I would replace the power bard and main board.
Nov 14, 2015 | Samsung UN50EH6000 50 LED HDTV
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Plasma tv video
Could be the power supply inside the TV is bad. Check with your local authorized Samsung repair center. DON'T try to fix it yourself.
Dec 03, 2013 | PN50C675 Samsung Factory Refurbished...
Hello i have a 42 inch samsung model number ln40b550 and i have been having this reaccuring problem where everytime i turn on my television it tends to flicker wildly for about the first 5-10 minutes, it...
This is a common Power Supply / Backlight Inverter Board issue. If you open up your TV you will see a long white board that is on the right side of your TV. You have to replace that board to get this issue fixed. You can find the board here BN44 00264B Samsung Power Supply Backlight Inverter
Jun 25, 2012 | Samsung LN40B550 40 in. LCD TV
Televison & Video Logo
114 people viewed this question
Jerry Greenberg
Jerry Greenberg
