Question about Cell Phones
How do i display available minutes on the front of my phone?
  • kakima Dec 02, 2016
    Hi Lydia Smith, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
Clear contact service display on nokia c2-00
How can i resolve this problem? Contact service
Dec 10, 2017 | Nokia mobile C2-00 Dual SIMbiosis
Quasar model MQ9968W keeps beeping every few minutes. How do I stop this noise?
Does it display any error code on the display like F1, F2 etc.,?
Mar 07, 2008 | Microwave Ovens
IPhone secret codes
<span><span> <p><span>Follow the list of latest Apple codes list: </span><br /></span><span> <p><b><span>Code Action</span></b><span> </span><br /></span><span> <p>*#06#<span> </span><span> </span><span><span> To display the IMEI Number of the mobile</span> </span><br /> <p>*225#<span> <span> </span></span><span>Use to display the balance detail of postpaid number</span><span><span> </span> </span><br /> <p>*#43# Use to verify if call waiting is enabled<br /> <p>*#61# Verify the number for unanswered calls<br /> <p>*#62# Verify the number for call forwarding if no service is available.<br /> <p> <br /> <p>*#67# Verify the number for call forwarding if phone is busy<br /> <p>*#646# <span> </span><span>Use to display the minute detail of postpaid number</span><span></span><br /> <p>*777# <span> Use to display the balance detail of prepaid number</span><span> </span> <br /></span><span> <p>*3001#12345#* Display the iphone inner settings<br /> <p>*#33# To verify whether barring is enabled or disabled for outgoing<br /> <p>*#21# <span>To display the </span>settings for your call forwarding<br /></span></span>
on Dec 02, 2010 | Cell Phones
Iphone no display no ringing
Open the battery and see if the wires are disconnected. Otherwise, take it in to your phone service people and have them check it.
Dec 04, 2017 | Apple iPhone 3G
Display Panel Problem.... my Onkyo TX-SR805 AV receiver works properly except No Display on the front panel. I follow the instruction troubleshooting on the manual by resetting the unit but to no...
I follow the instruction troubleshooting on the manual by resetting the unit but to no avail. It's beyond warranty period.
please help, thank you
Sep 27, 2010 | Audio Players & Recorders
Horizontal lines on front display
The screen has cracked. If this isn't a physical damage andthe phone is under warranty; you must take the phone to the nearest nokia care and avail the warranty.
Oct 19, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Front screen is blank and won't display
i think your flex ( the one w/c connects the lawer and upper part of your phone has a problem). you need to realine ore totally replace the flex. you can ask with celphone cervice center near you. good lack,,,,,,,
Dec 07, 2008 | Motorola Mobility KRZR K1m Cellular Phone
Samsung a950 main screen display is backwards and upside down
My Samsung U700 had the same problem (display went back-to-front and colours all reversed and low-res.) It seems to be a problem with the flex cable (the cable between the main phone body and the sliding screen) wearing down and screwing up the data being carried between the display and the phone. Flex cables are cheap to buy and there's plenty of info online showing how to replace them yourself. Good-luck. Google: samsung u700 replacement flex cable
Jul 05, 2008 | Samsung SCH-a950 Cellular Phone
Dust under motorizr z3 screen
Richard from UK
WARNING - DO NOT ATTEMPT THIS IF YOU ARE AT ALL UNSURE, AND DO NOT ATTEMPT THIS IF YOU DO NOT WISH TO RISK VOIDING YOUR WARRENTY!!!!! Turn off your phone, flip up the front panel and place the phone face down on a soft surface. Use a Torx T5 screwdriver/bit (available from some hardware/electronics stores or online) to carefully unscrew the small screws from the reverse of the front panel. Do not loose these!!! If you turn the phone over you should now be able to lift the top of the front cover away from the display, then slide down slightly to free it from the bottom of the display. Be very careful at this point as there is a small ribbon cable connecting the front cover buttons to the rest of the phone!!! This can be unplugged from the display board by carefully lifting it away, you may need to use a small screwdriver to gently lever it up but in my case this was not necessary. Now use a blower brush (available from any good camera shop) to blow away the dust from both the LCD display and the inside of the front cover. Then simply reassemble the phone by following the above instructions in reverse. Voila - dust free Z3!
Oct 30, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
