Change region code on zennox dvd player - Televison & Video
    Sergeant:
  • 246 Answers
You may only change region 2 times. it may be stuck in the region selected if done multiple times. go to settings and chnge it if available
Posted on Dec 01, 2016
Tip
DVD region code
Generally, your Pioneer DVD 120K player can play any DVDs from your region. As you encounter the situation that can not play the DVD, i guess your DVD from other region. To change the region code of DVD is High-risk operation, it only can be changed less than 5 time, and you are not to recommended to do that. If only for one or several DVD Discs, just remove the DVD region code via a DVD ripper. Of course, if you bought the DVD player from other region, you can change the region code of DVD player permanently.
on Jan 18, 2014 | Pioneer DV120K Player
How do I change region code on dvd player?
I'm almost positive you can't change the region code, because it is in the firmware of the DVD player.
Jul 21, 2014 | Philips Audio Players & Recorders
Change region code
I dont know how to change the region code of dvd player, but i ever read an article talking about how to remove region code from DVD disc. Here it is: http://drm-assistant.com/dvdtips/how-to-bypass-dvd-region-code.html
Nov 09, 2013 | Magnavox DV220MW9 DVD Player VCR
Cant play a region 1 dvd
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Jul 12, 2011 | Audio Players & Recorders
Is there a code to change a Thomson TV DVD combo to multi region - Model L26D?
In a word....NO.
Only DVD's themselves can be multi-region (region code 0).
I always advise on this site that you NEVER change the region code on your DVD player! Here is why....
To prevent DVD copy piracy, every DVD player from EVERY manufacturer allows (if it is allowed at all) only TWO changes to the region code. A third attempt to change the region code permanently locks the player and turns it into a paperweight.
If you happen to be the rare exception to the rule.... that you have moved to a new place that requires you to change the region code to view locally purchased DVD's, then by all means change it ONCE to be able to use your DVD player. Please remember that you can only change it one more time after that though! You will unfortunately not be able to watch DVD's that are from your old region.
Feb 15, 2011 | Televison & Video
My cousin bought a Phillips Portable DVD player for my kids. He bought it in America and in South Africa we have a different region code, can I change the region code
Question Can I change the region code on my player so that I can play DVD / Blu-ray disc from other regions? Answer South Africa is region B for Blu-Ray DVD and Region 5 for DVD and finding the procedure will be difficult as international copyright legislation prohibits manufacturers from providing instructions for changing the region code.
Jan 01, 2011 | Philips PET740237 7 in Portable DVD Player
Mac book pro is currently locked to region 1,
Home Index DVD Region Codes
In order for you to view a DVD's content, the region code on the DVD and the region code for DVD Player must be the same. Your DVD drive is automatically set to a region code the first time you play a coded DVD. If the region code for a DVD does not match the current region code for DVD Player, a dialog appears for you to change the code for DVD Player.
IMPORTANT: You can set the region code for DVD Player only five times (including the original setting). The fifth time you change the code, it will be permanently set. The following map and table indicate the code for the various regions. Some DVD discs can be played in any region, and are sometimes referred to as having region code 0. These discs can be played regardless of the region to which DVD Player is set.
Mar 30, 2009 | Apple Computers & Internet
Our Sony DVD player will not playimported DVDs from the UStates
1) those DVDs are coded in Region 1(Canada, United States; U.S. territories; Bermuda)
you will have to change the region code on the dvd-rom to region 1
2) if you bought the stand alone DVD player in the U.S. it will play region 1 dvds and nothing else(some dvd players will play region code 1-6)
3) to change the code in windows vista you'll have to go under the drive property's in the device manager go to the dvd region tab and set it to what ever the number on the back of the dvd is WARNING you only get 4 changes before the drive locks you out permanently then your stuck with what ever number you put in on the 4th try you've been warned
windows xp/2000/98/me
you'll have to change the region code from your software player again your limited on how many times you can change the region code before you have to reinstall the dvd player software
Feb 02, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
Incorrect region codde
This is for DVP31XXX series i hope it works all on DVP31 series. It has been tested on DVP3146K /51 and it has been worked...
1. Make sure there is no disc in the player.
2. Turn power off and on again.
3. Open the tray.
4. On the remote, hit 9879 and then 0. This changes unit to Region 0, meaning it'll play all regions.
5. Hit OK on the remote.
Good Luck Guys!
Apr 27, 2007 | Philips DVD 622 DVD Player
Televison & Video Logo
Top Televison & Video Experts
