What is the difference btween a BRD 2000 and BRD 2680
Mthr brd FC-GB/ 7VM333M-RZ not working ???
you want to take an format cd an insert it and format the full system and install an windows xp pro as ur operating system and put an 1 gb ram in it
Mar 30, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
I have a VGC-RB33GY PC and my monitor stays blank when I turn on the PC. I know the monitor is working because I have pluged it into another computer without a problem. Is it my graphic card or the mother...
It sounds like it is the graphics card but first i would reinstall the driver and see if that works if not Identify the card and find out what type it is PCI or VGA you can order one at Amazon and find the one that you wane to get also Tiger Direct has a large selection
Aug 28, 2011 | Sony VAIO VGC-RB33GY PC Desktop
Cmptr not working
reinstall your Windows
Jun 30, 2009 | Gateway GT5654 Desktop PC
Ps3 wont start error code 80010514
Two things it could be. Either corrupted disc (formatting will not help this since it's caused by moving the unit while running, damaging the disc and not corrupting files) or your BRD is malfunctioning. If it is only on games and not on movies,
I would say it's the HDD, if it's on everything, then the BRD. You can get repair parts on Ebay for the BRD by punching in KES-400AAA and it takes about 15 min. for an expert and about an hour and a half for a newbie to replace. Good luck.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
HDMI and Non-HDMI for xbox360, is there any difference in gaming?
well the hdmi will give you a better picture and pretty much all games support the hdmi. but the big one is the difference btween 1080i and 720. 720 may be your best choice for a tv because most games use that as there base setting and thats what there meant for. although newer games are coming out with 1080i as their prefered setting
Jan 31, 2009 | Microsoft Xbox 360 Console
On the harp al-1631 what does the flashing f then 5 mean ?
*** ALWAYS DICONNECT POWER SOURCE BEFORE REPAIRS****
Check and clean white stripe, make sure it is clean and white.
Check and /or Replace the exposure lamp, they go bad and cause F-5.
If lamp is good, replace exposure lamp sensor.
Check connector ( flat cable) connections to scanner brd.
Replace scanner brd ( board) if defective.
If scanner brd is good, replace power brd.
Jan 18, 2009 | Sharp AL 1631 Copier
Black screen on my hitachi ultravision 55 inch plasma tv
With a black screen, it could be any number of things. You cold have a bad Y sustain brd, Z sustain brd, digital brd, etc. As the tv powers on it develops turn on signals to the power supply. If there are any bad drive boards, these signals will not be developed thus not allowing the power supply to fully energize. This repair will probably require a qualified technician.
Nov 26, 2008 | Televison & Video
Replaced convergence brd but now picture goes dark and audio stays on
I would suggest to go back and make sure that all the connectors are firmly inserted in their respective plugs.
Let me know if you need further assistance.
Apr 09, 2008 | Samsung HCM4215W 42" Rear Projection...
Picture turned pink
This all of the sudden happened if so you may have lost the green alot of times yoiu can fix the CRT drive Brd there is a video amp ic and a resistor that can be replaced or yo can replace the whole Brd a little harder to do than just replacing the parts on the Brd
Oct 17, 2007 | Samsung HC-P5241W 52" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
