Question about Coleman Electrical Supplies
Coleman power mate won't start. Plug is good, fuel is getting to carb. If I use starter spray it will run for a few seconds and die.
  • 660 Answers
Sounds like a sticking float or clogged needle jet inside the carb.
i'm currently working on exactly that same issue
Coleman power mate won't start.  Plug is good, fue - 26381131-bquajmf3wtqoccqehhe3sjc5-5-0.jpg
Posted on Dec 01, 2016
I have a cub cadet GT 2550. Has new battery cranks but will not start. Thinking it's not getting fuel. Checked fuel filter and fuel flows through.
If spraying starter fluid in the intake causes it to run for a few seconds, then you have a fuel problem. That starter fluid is the fuel. If it didn't have spark, it still wouldn't run. I would start checking the carb and make sure nothing is stuck or plugged.
Apr 18, 2017 | Motorcycles
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Why does my briggs and straten model 313-707 hard start then dies after a few seconds when it is running it acts like it's starving for fuel replaced fuel filter fuel cap and cleaned carb
Try replacing the plug.could also be a spark problem from the coil .you can purchase a spark tester which you can fit between the plug and lead .pull start mower and watch if spark is good.if ok then get a can of carby clean start mower and spray carby clean spareingly while running and if it keeps going the fuel is the problem
Aug 14, 2014 | Garden
Tiller won t start
The fact that it started for any length of time, tells you the engine functions. The engine is STARVED of fuel mixture. Either the inside fuel line is clogged and needs to be blown out or the carbonator adjustment is incorrect. Check to see that the spark plug GAP is proper and when placed back into the engine it is hand tight with the spark plug wire formly in place.
Mar 01, 2014 | Husqvarna Garden
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Earthquake tiller viper 43cc engine will not start
I have the same issue, I thought it was the carburetor so I cleaned it and put it back together, same issue, I put a new carburetor on it same issue, has great spark, if I spray carb cleaner into it, it will start and run for a few seconds even throttle up, but then it dies, and will not start again without carb cleaner spray, and fuel is fresh and properly mixed, very confusing indeed.
Apr 17, 2012 | Ardisam Earthquake Mini Cultivator 43cc...
Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Nov 05, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate 5000 starts with starter fluid, but leaks gas into the air filter. Checked the float, it has no holes, and is not jammed. Fuel will go into the carburetor, but no fuel will reach the...
Sounds like you need to clean the carb ports, lines, jets, etc... purchase a carb spray cleaner with a tube to place on the spray head (Berryman's Chemtool B-12 is awesome). Take the carb loose from the generator, and remove the bowl, needle valve and spray carb cleaner thru all the holes, lines in the carb. Reinstall complete with air cleaner and retry... also if the gas is old, drain and replace with new...
May 25, 2009 | Coleman Powermate Powermate 5000W...
My Coleman OHV 3000 will not start
dont use starter fluid ,will ruin engine.Sounds like the float in the carb is stuck.and keep lookin for a filter.
Dec 21, 2008 | Coleman Powermate Premium Plus 6250W...
Engine dies
Your carburator is gummed up !
Take the float bowl on the bottom of the carb and spray the main fuel jet out with cleaner, do this to the idle needle valve also. If that don't work pull the carb & take apart & soak overnight in parts cleaner & blow out all ports & orfices with compressed air.
Next time you store your generator with gas in it , use a fuel stabilizer !
Good luck !
Oct 05, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
35 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
