Fisher &Paykel smart drive PRIDE 5.5 WON'T START No power-how can I fix is there a fuse?
aborcass
  • 2651 Answers
SOURCE: Fisher and Paykel Smart Dribe 608
not familliar with that exact model number ( we dont have that over here in the US) we have simalair f&p gwl10- gwl11) that problem sounds as if either the pump is bad and overheating before pumping all the water or a diverter valve is not fully closing allowing water to remain in tub.
Posted on Mar 29, 2008
SOURCE: Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Posted on Dec 16, 2008
  • 19 Answers
SOURCE: Fisher & Paykel Pride 5.5 Smartdrive 8 not spining
There is a transmission clutch that engages for the spin cycle. A gear has worn or broken a tooth. Replacement of the transmission hispeed spin cycle assembly is required.
The other comments are of no use. You must get parts from an Authorized Fisher & Paykel dealer, or have an authorized repairman service the machine.
Posted on Apr 12, 2009
  • 69 Answers
SOURCE: How to I get to the pump on my Fisher & Paykel
If machine has water in it, bucket out as much as you can.
To access pump:
-Pull machine forward and lean it backwards so you can access under machine.
-On the front right hand side, you will see a fan blade- this is the drain pump. This fan blade should spin freely if you turn it by hand.
-To remove pump: remove plug connection that has 2 wires. Remove other plug connection that has 1 wire. On the top of the pump assembly, you will see a white plastic tag, about a 40mm long horizontally across the pump- gently pull tag towards you, and turn complete pump unit anti clockwise- whole pump will drop out (don't force it, it should come out easily) *Note* if there is water in machine still, it will come out when you remove pump assembly- be ready with some towels!!
-Check pump impellor(blade on other end of pump) is free from obstruction, and turns easily. Check with your finger to see if there is any obstruction in the hole where the pump has come out of (inside bowl).
-You can test pump with an ohm meter (should be approx 37ohms from memory)
Reassemble and test for leaks etc
Posted on Aug 11, 2009
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
Cold water not pulling into Fisher & Paykel 5.5kg Smart Drive Pride.
Either the cold water inlet solenoid has failed or there is a fault with the electronic control module, Unfortunately the only way to find out is to replace the cold water solenoid and see if it works, if it doesn't then the electronic control board is faulty.
Mar 16, 2017 | Fisher Washing Machines
Done a load of washing hung it out came in to do another load & have no power.
unplug the machine for five minutes and try it again. That is your RESET
Apr 24, 2016 | Washing Machines
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher
shorted water pump will take out the control ... new fuse added with New controls
Jun 17, 2013 | Washing Machines
Fisher and Paykel Kelvinator Pride 5.5 Smart Drive 9
You need to read the error code
and tell me what lights are on
Aug 17, 2012 | Fisher Paykel Eco IWL16
Washing machine cuts out
The pump is over heating and cutting power.
Mar 30, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel Smart Drive 9, pride 5.5 turns on by itself and beeps
Probably a bad controller. Note the lights that are illuminated and call F/P.
Jul 02, 2009 | Fisher and Paykel GWL11 Top Load Washer
Aug 04, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
