Question about Microwave Ovens
TECH MAG 6 TRAINER gets hot and makes noise after I use it for about 15 minutes
    New Friend:
    Problem Solver:
  • 9 Answers
Sounds as if it is not ventilating the heat properly, which is causing a safety mechanism to be triggered to shut down the microwave in order to save the motor.
The vent could be blocked, the fan/fanswitch went out, or the heat sync is no longer properly transferring heat. Depending on the age the solution would to call a repair man or replace the microwave. And never use microwave without anything inside of it.
Posted on Dec 01, 2016
My Kitchenaid Superba kaw38avm726 microwave does not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Nov 20, 2009 | KitchenAid KEMC377K Convection / Microwave...
I have a GE Microwave Model JVM1540LM2CS. It started making funny noises like a fan or gear grinding and then it quit working altogether. I have checked the circuit breakers in the house and have...
sounds like the mag fan went out and blew the internal fuse they are ceramic fuses 15 or 20 amp available at hardware stores ,if this blows again it could be the mag overheated,but the thermal breaker should have shut it off before this,thenit can also be your h.v. diode or capacitor shorted
Oct 10, 2009 | Microwave Ovens
Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
Sep 10, 2009 | Magic Chef CMV1000B Microwave Oven
Oven will only run for a minute twenty six, then it shuts down, and comes back up twenty minutes later
your thermal cutout on the side of the magnetron is defective,sounds like the mag is getting very hot,and taking a long time to cool so thermal can reset
Sep 07, 2009 | Microwave Ovens
Makes a loud buzzing noise and does not get hot
Have seen this many times.
Sounds like a bad CAP since a bad diode would blow the fuse and a bad mag would likely do the same thing.
Since yours is making the loud 60hz buzz you need to replace the capacator that will likely fix the problem. A $10 fix
Jan 06, 2009 | Kenmore 62622 Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
Amana RFS12SW2 microwave. Mag is overheating; the TCO is working properly and shuts the oven off at 325 degrees F. I replaced it for good measure and it made no difference. It takes on average 2...
I contacted Amana tech support. They stated to check that the stirrer was revolving and to make sure I had the cover back on the microwave. Once the cover was put back on and the grease shield was in place, the stirrer did revolve and the magnetron no longer overheated.
Aug 29, 2008 | Microwave Ovens
Microwave sedems to be working but not heating
We woke up one morning and our microwave had no power. I checked the breaker and outlet they are working. Any help
Mar 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE jvm1190 above the range microwave /convection (2001 model)
It sounds just like the magnetron is bad, overheating and opening the thermostat. This is how it would work if that were the case.
One other thing is to be sure that the cooling fan is running and that you feel air flow.
You should check the air filter and grille, as well as the outside vent for any blockage.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa:
You can find helpful exploded view diagrams and order parts by entering your model number here:
Oct 10, 2007 | GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
