Question about Whirlpool G7CE3635 Cooktop
Stove top amped or watts Modle # G7CE3635
The 40 amp breaker keeps tripping when you use the two large burners at the same time. i want to know if the stove is drawing to much power for our breaker. When using the small burners the breakers never trip.
5 Suggested Answers
  • 7 Answers
SOURCE: stove keeps tripping fuse
when turning on stove, the current inrush is too great for the breaker. you need to look at the data plate on stove first to see if the current (amp) usage is greater than your breaker. If not, then you may have a faulty element or control
Posted on Jul 02, 2009
motor1258
  • 6674 Answers
SOURCE: whirlpool stove top- two problems. 1) burner is
If all other burners working as they should, I'd check that bad one for partially plugged orifice. Try poking a small piece of wire through orifice hole to clean it. As far as igniter goes, and they are all connected to one source for spark, and separate wires run to each, make sure there is no breaks in small wire, as well as check that little ceramic igniter has a clean tip, if not clean with nail file or sand paper, and make sure it is same position at burner as others, as in close enough for spark to arc across to burner. if still no spark, try swapping wire with another, if it works, change wire, if not replace little ceramic piece at burner.
Posted on Aug 08, 2009
  • 500 Answers
SOURCE: Gas stove tops: After 3-4 minutes
Hi abbilou_78,
I believe your ignition switches have come in to contact with either water or moisture.
Please read my below Tip on how to fix the problem:
GAS KITCHEN APPLIANCE CLICKING SOUND...
If it does not solve your problem, I'd suggest replacing the ignition switches.
Kind Regards
JEDEMEYER1
* If you found this solution helpful, please rate it
Posted on Aug 03, 2011
AndrexT
  • 19719 Answers
SOURCE: My left front burner was turned off for almost half hour but remained hot. the hot surface light was still lit. I had to throw my main breaker to turn it off. What could be my problem
Sounds like the thermostat on that burner gas gone. When you switched the breaker back on, did the burner get warm after being cold? If so, you need a new controller. They are easy to change if you can get to the back of the unit. Make sure you turn off the breaker and physically remove the plug.
Posted on Nov 24, 2013
Maytag electric cooktop popping breaker.
The problem is most likely in the element in one of the coils, if they are the tube type and look like pencil thick heating elements, they can develope a short circuit inside them. The actual heating wire is encased with ceramic filler and then put in that tube. The heating wire moves when it gets hot and can work its way to the case and cause a short. Unhook the power from the whole unit and use the meter to check the rersistance of the coils between the heating element and the case
Jan 13, 2013 | Cooktops
Large electric burner will not turn on
you need to check the wiring to that burner it appears that there has been a short to the burner
Apr 04, 2010 | Jenn-Air 35 in. JEC9536ADS Electric...
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
I'm getting a major short in the area of the control knobs. It trips the breaker immediately even with no burners turned on. I pulled hte top and there is no obvious short or bare/burned wire. Wondering if...
If your burners are the Calrod type, check if one of those may be shorted. Disconnect them and tape or insulate the wires for a test.
One side of the burners may be hot all the time so don't rely on whether they are turned on or not.
For troubleshooting, a trick is to put a 100 watt lamp in series with each side of the line so that testing can be done without blowing the breaker.
Jan 06, 2010 | GE Cooktops
Stove keeps tripping fuse
Jul 02, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Stove is tripping circuit breaker Two burners stopped working properly (only get slightly warm). Switched the coils to the other side and the other side is still working. Looked underneath and saw that...
if it is an old stove i would say have it serviced/checked over. if it is a newer stove i am guessing the circuit breaker predates it and is rated for the old stove therefore you will need to have a larger circuit breaker installed (by a licenced electrician)
Mar 04, 2009 | Jenn-Air Expressions AC110 Electric...
Electric Glass GE Profile Cooktop Burner popping
yes the knob is attached to a switch and the switch to the burner by way of wires..you can get into the cook top.but with your description of whats going on i would have the switch with me and then may only have too take apart once.there is a chance your burner is bad,but as you describe the way the switch is acting is seems pretty sure just the switch.you can order switch on line you need your model and ser#
Jan 30, 2009 | GE Profile JGP636 Gas Cooktop
GE profile performance electric cook top is not producing enough heat in the front burners.
Confirm there is 240 VAC powering the unit (make sure a breaker has not tripped or a fuse blown.).
Did the burners ever produce enough heat?
If yes, then we can look deeper. If no, then the burners may not be adequate for your cooking style. Burners are like light bulbs. A 60 watt bulb will put out more light than a 40 watt bulb. A 100 watt bulb will put out more light than a 60.
Typically, a small burner will provide less cooking heat than a large burner.
Jan 23, 2009 | GE 30 in. JP340 Electric Cooktop
My electric stove top burner only works on high
This is for the glass top units. well i'm not sure if your problem is with your large or small single burner or the large expandable burner. If it's the large or small single burner replace the burner and if it the expandable also replace the burner. If you have a coil burner replace the infinite switch. Good luck hope this helps you.
Jan 09, 2009 | Jenn-Air JED8430 Electric Cooktop
Stove top keeps turning off
if your breakers have become week they may trip with a lesser amp draw.sooooo if they trip right when you turn on a switch on the range, then it is a short in the range.if it trips after your using it abit its your breaker.hope it helps God bless ,tom
Jan 08, 2009 | Jenn-Air JED8230 Electric Cooktop
Whirlpool G7CE3635 Cooktop Logo
101 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
