Hi just installed a new SC board #TNPA5351 AF and the old # was TNPA5351 will the part # interchange tv model TC-P46ST30 Thank you
  • 11800 Answers
SOURCE: Just installed a Panasonic model
Your remote is an older model, that was designed and programmed well before your tv, so it's highly unlikely that it will support it. According to the manual
http://www22.verizon.com/nroneretail/nr/rdonlyres/0d93f875-4498-460f-8fc4-a15d519b4e7c/0/welcomekitremotecontrolinsrt_nc.pdf
these are the codes you should try : 0277,0078, 0677, 1437
If none of them work then your only option is to perform a code scan, maybe the code for another tv will match yours. If even this fails then sorry, your FIOS remote is incompatible with your new tv.
Posted on Oct 18, 2010
gopakumarg43
  • 73647 Answers
SOURCE: TC-P46G25 - 3 months old
Hello
There are two types of guarante that a company offers to a customer. You must read the warrany conditions very well before buying any product. Some of them will give replacement waranty to their product. Some of them will offer only warannty. For the first, if the set shows any problem during its warranty period, the company will replace it with a new one without any question. For the second, they give only wararnty to you. Not a replacement waranty. They have only to do is to repair the faulty set and get it back to you. That is all. Sometimes, there may be delay in getting the spare parts. Sometimes it may tak months. There is no predicted time for that. On some occations, they will ask you the cost of component, as thay claim that the failure occured by your use. If so, that amoun vertually contain their service charge too. I thinks that you got me.
So when you go to buy an other product, buy ony the product that the company assures replacement warranty for a period of 6 months or so. If you have bought the set without replacement warranty now, you will have to suffer. OK.
Posted on Mar 23, 2011
alpug
  • 1961 Answers
SOURCE: Hello, I have a Panasonic
have you already checked the power supply section sir?power failure are often cause by a faulty capacitors at the power supply section.have a close look at the capacitors if you notice a deformed/bulging capacitors replace it and also resolder the components at the power supply board..
let me hear from you.
Posted on Mar 24, 2011
bobhifi
  • 635 Answers
SOURCE: I just bought Panasonic SC-PT480P-K
Let us take things step by step.
1) If you have an AV cable ( Yellow /Red/White ) try connecting the DVD players composite out (Y/R/W) to the TV's composite in. Select AV input instead of HDMI on the TV and see if you are getting an image. This is to confirm that the DVD video circuit is OK.
2) If all is OK in step one you can try buying a good HDMI v1.3 cable. You do not need a v1.4 cable which is only good for 3D bluray players.
Revert back for more.
Posted on Apr 02, 2011
bugoy31
  • 1238 Answers
SOURCE: i have replaced the p board and sc boards in this panasonic tc-p50s30 viera tv and still have the 7 red blinks? what else can be wrong?
7 blinks is indicate for faulty power supply however if you already replace it the possible problem is on main board..
Posted on Jun 07, 2012
Hi just installed a new sc board #TNPA5351 AF and the old # was TNPA5351 will the part numbers interchange thank you Terry
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 30, 2016 | Panasonic Televison & Video
Panasonic Plasma TV TC-P50S2 10 blinks
Sounds like main digital board fault. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 11, 2016 | Panasonic Viera TC-P50S2 50" Plasma TV
??How to fix a PANASONIC PLASMA TC-P60UT50
Could be the SC, but also might be either the SU/ SD causing the SC to go into protect. Pretty easy to determine, if you look at the SU SD and see any holes or burn cracks that would be the problem. Let me know if this works or can help further.
Apr 13, 2016 | Panasonic Televison & Video
What would cause sound but no pic on a Panasoniv LED TV?.
Back-light problem.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 06, 2014 | Panasonic TC P46ST30 - 46" VIERA ST30...
I was told I need this part TXNSC1NVUUB but has been discintinued
TXNSC1NVUU I guess this is the alternative to it but I cannot find either one any where! F panasonic ! 2 year old 2300$ tv!
Jan 06, 2014 | Panasonic " VIERA 55"" Class / Plasma /...
No picture and power light blinks 7 times on my viera tc-p50st30 plasma tv when it is turned on
That can be caused by either the SC or SD board. Contact the people at www.tvrepairworld.com they can assist with proper diagnosis and they also should have the replacement board
Jun 01, 2012 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
I just bought Panasonic SC-PT480P-K DVD home theater and TC-P46ST30 TV. I connect DVD HDMI output to TV HDMI input port #1. But when I try to play DVD, I just got sound out to the home theater speakers...
Mar 07, 2011 | Panasonic SCPT480 Theater System
My TV just turned off and the power light flashes 8 times. what is the flash code for 8 times on a panasonic TC-50PS14
thought I would post this here for everyone.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
May 14, 2010 | Panasonic Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
