I have checked the ups connection for my via1535,and my drive to be the latest version.All that I get is "connecting"which it does'nt and wanting to alter my computer(I have said okay)what next?
SOURCE: trying to connect tomtom 910
pressed RESET button on TomTom & usb device then recognised.
Posted on Jul 17, 2008
SOURCE: Navman ICN 720 GPS device
Do the following: (1) find 'Microsoft Active Sync' - if you can't find it easily use the 'search' facility (start,search, all files and folders. enter 'Microsoft Active Sync') when it comes up click on its icon. It should now be loaded and your ICN will be recognised ready to transfer/remove maps. Ken
Posted on Nov 11, 2008
  • 18 Answers
SOURCE: MY ZOOMBROWSER EX 5.8 TELLS
Sounds like the computer need to be rebooted.
Posted on Nov 17, 2008
  • 92 Answers
SOURCE: ipod nano wont connect to pc
Try this out
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
then try to change the drive letter:
  1. Open the Control Panel.
  2. Double click on Administrative Tools. Note: If you don't see Administrative Tools, look at the left column in Control Panel for a link that says, "Switch to Classic View," and click it.
  3. Double click on Computer Management.
  4. In the left column, click on Disk Management.
  5. Locate the iPod and right click on it, then click Change Drive Letter and Paths.
  6. Click the Change button.
  7. Use the drop-down menu to select a new drive letter. Note: Make sure to choose a new drive letter that is not already assigned to a network drive. The drop-down menu will display all available letters that are not assigned to a physical drive. Drive letters that are assigned to a network volume will still be listed here. It is also a good idea to assign a drive letter other than a, b, c, or d, as these letters are usually reserved for other system drives.
  8. Click OK.
  9. Click Yes on the confirmation dialog.
  10. Close the Computer Management window.
  11. Restart your computer.
Then try to restore the ipod to factory settings:
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
This has to resove your issue
Posted on Feb 04, 2009
  • 92 Answers
SOURCE: Ipod Nano 4th Gen 8
So what you can do is connect the ipod to computer (Connect it to USB Port at the rear of you desktop computer and charge it). then try these steps:
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Can't download anything on my Acer Aspire 5552-3691
I don't see a question above, so I'll just assume that you're asking how to fix your computer so that you can connect to the internet. Is that correct?
If so and since you have reset your computer back to factory settings, you should check that all of your software is updated to the latest versions. This would include your operating system and drivers.
Then, you should check that your computer can connect to the internet via ethernet (RJ-45) cable. You would want to directly connect your laptop using the ethernet cable to your router. If this works, you can move on to trying to connect via Wi-Fi. If this doesn't work, you should check that there are no software/driver issues and/or hardware issues with your computer.
If you are trying to connect via Wi-Fi, again you will want to check that all drivers and software are up to date (so that you are on the latest versions of your operating system and the Wi-Fi care inside your computer has the latest driver so that it can connect to your wireless router). Then you will want to attempt to connect and most likely re-input your Wi-Fi password.
Dec 30, 2013 | Acer Aspire 5552-3691-24271 Laptop
What's the most current OS I can use to replace Windows 98 on a Compaq Presario 1277 laptop?
You might be able to find a stripped down version of XP or put Windows NT on it. Those are my best guesses. NT will let you use newer versions of some browsers as well. Mostly Explorer
Dec 11, 2012 | HP (158800-001) for Compaq Presario 1246,...
No maps found
When your tom tom comes up with the no maps found error message. There are several causes to the problem.
If you updated your map using the latest map guarantee and then get the error No maps found, make sure you install the latest version of the TomTom application.
Check for the latest application: Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
You can check the version of your application in TomTom HOME. Connect your device and then click Manage my device and select the Items on my device tab. Expand Applications and then click More info.
Your map may require the latest version of the TomTom application.
Check for the latest application Connect your navigation device or memory card to your computer and click Update my device in TomTom HOME to check if a new application is available.
HOME may not immediately offer the latest application version when installing a downloadable map on a blank memory card. Re-connect your memory card to HOME and check for the latest application by clicking Update my device in HOME. HOME this time offers the latest application for your device. Try Installing maps on a new memory card
You need to also make sure all files are in the right places. Browse the content of your navigation device:
Windows XP: Click Start > My Computer and then double-click the removable drive of your device.
Windows 7 / Windows Vista: Click the Windows start button > Computer and then double-click the removable drive of your device.
Mac OS X: Double-click the desktop icon of your navigation device.
Check the following:
The map folder (e.g. Western_Europe) needs to be located in the root directory of your navigation device or memory card. This means the map folder may not be inside another folder. Before you move the map folder we recommend that you create a manual backup.
The map folder needs to contain at least the following files
cline.dat cname.dat cnode.dat faces.dat mapinfo.dat poi.dat tables.dat tmccodes.dat traffic.dat .meta (map v705 or higher will have/need this file) .meta.dct (map v705 or higher will have/need this file) .pna
If any of these files are missing restore a previously made backup or re-install your map to your device (in TomTom HOME click Add Traffic, Voices, Safety Cameras etc. > Items on my computer).
Hpe this was helpful. Thanks for using fixya.
Jan 26, 2011 | Tomtom ONE GPS Receiver
On Farmville, when I go to collect gifts, these messages always come up and it won't open my market or collect gifts. Please help! Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0;...
You can try three things, first, download and install the latest version of Flash
http://get.adobe.com/flashplayer/
If that doesn't work, try reinstalling your browser, from that error code it looks as if your using a Mozilla based browser, probably Firefox, Sea Monkey or Flock?
Download the latest version of Firefox here: http://www.mozilla.com/en-US/firefox/firefox.html
Download the latest version of Flock here: http://flock.com/
Download the latest version of Sea Monkey here: http://www.seamonkey-project.org/
Third you can try downloading and using a different browser. there are several that I would recommend:
Safari: http://www.apple.com/safari/
Google Chrome: http://www.google.com/chrome
or Opera: http://www.opera.com/
Hope this helps!
Nov 24, 2009 | Facebook Social Network
Message saying "no connection between PC and printer. Installed new USB cable and it works for 2 weeks, then "no connection notice again". Uninstalled and reinstalled Dell printer software and no help.
hi jaromarburge,
you can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
Oct 12, 2009 | Dell 922 All-In-One InkJet Printer
I want to use inernate on computer via mobile N95
its actually simple. just enable gprs on ur mobile by requesting to your service provider via customer care or dealers. Then download latest nokia pc suit.if i'm nt worong it must be version 7. sumthing.install it in ur PC then take connect to internet n then select settings in this connect to internet window. there u'll have select ur service provide from the lsiting.then click finish n then click on the connect to internet icon which is on the same window.nw the internet should be working fine..thank you.
Feb 11, 2009 | Nokia N95 Cellular Phone
Printer is nt connected to laptop,driver is installed bt nt wrkin
Here is the HP website for your product. Start with the version of windows that you have and download the latest software and drivers based upon that version. I am fairly sure that may be the problem.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=441125&lc=en&cc=us&dlc=en&submit.y=1&submit.x=4&cc=us〈=en
Dec 29, 2008 | HP Officejet 5610 All-In-One InkJet...
I have Wyse V50L termimals that cannot connect to Terminal Server 2008. Connections from XP Remote Desktop Client work fine. The server is configured to not use Network Level Authentication. The...
Have you tried the latest V50L firmware version? There was a major revision lately?
http://www.wyse.com/serviceandsupport/support/downloads.asp
Oct 25, 2008 | WYSE Computers & Internet
Apple ipod classic 160 gb
connect ipod to pc..........let itunes (make sure it the latest version) come up....your ipod icon shows up update (let itunes check if your firmware is up-to-date) if so this should do the trick.
Jul 13, 2008 | Apple iPod classic MP3 Player
 Grubhead
Grubhead
