Question about Dryers
Dayton 2YU78 part numbers
Specifically the heat coils
I need a wiring diagram for a dayton 1rkt5a portable heater
Call Grainger with the model and serial number. Hopefully they can help you
Jan 16, 2018 | Dayton Heating & Cooling
90000 btu high intensity infrared ceiling hung heat. Have replace twice and Honeywell gas valve once. Always starts and runs first time then never starts again. Coils on gas valve keep burning up. ??
Dayton 3E134E Troubleshooting guide - manualzz.com
manualzz.com/doc/1285710/dayton-3e134e-troubleshooting-guide
This heater must be installed and serviced by trained gas installation and service ... Dayton High-Intensity Heaters ® Description Dayton high-intensity heaters ... ofinfrared radiation by heating a ceramic refractory material to incandescence. ..... 3E133, 3E461, 5VD63, 5VD64 90,000 BTU/H Do not mount heater horizontally.
[PDF]Fall Heating - Plumbing & HVAC
plumbingandhvac.ca/images/documents/PHVAC_Sept-Oct03.pdf
Nova Scotia gas utility eyes dealer network ... valve underbody and screw trim pieces ... Infrared requires a different way of ... gives you a crisp picture, and speeds up pipe locating. ... tiative will keep HVAC contractors busy ..... labelling for equipment usinghigh pressure R410A ..... Multi fired from 90,000 to 179,000 btu/h.
Jan 05, 2016 | Dryers
Is Dayton electric heater # 2e669a a 110v or 220v
I can't find that model number. The closest I came was this page. Some heaters are 110, some are 240. I couldn't find a manufacturer page either.
Dayton Heaters Electric Oil Fired Gas Fired Heating Solutions
Oct 28, 2015 | Dryers
Dayton heater mod 2yu59 is not heating up?
Need to check the low voltage circuit for 24 volts, the 480 volt to 24 volt transformer may have a circuit protection reset or fuse installed. All the 3 phase electric heaters use a low voltage control circuit for operation of relays (24 volt coils).
Nov 22, 2011 | Dayton 2YU59 Electric Heater
Is there any place to get a heating element for an OLD Dayton Electric Garage Heater..... model 3E087..... 240V, 10,000watt. It has a circular heating element, and only the inner most part of the element...
I think your best bet is to go to Grainger.com. and go to repair parts for dayton furnaces with your model and serial number and part no. if possible. You can also call1-800-323-0620 and get location of dealer nearest to you.
I have dealt with them for many years and they have always treated me right.Not always the cheapest but I have been happy with the service and the expertise of their staff. I hope this helps you and have a good new year.
Thank you.
Dec 27, 2010 | Dayton Electric Heater
Model 6a858 what does each pin do 6and 7 are a n/o contact ,1,2 and 3are what configuration. Running 2 load augers for agrain bin ,want to run 2nd one 5sec longer
Load can't exceed 1 amp, so you'll need a contactor with 120 Volt coil to control load augers.
To run 2 load augers, you need a second Dayton time delay. And another contactor.
Contactors:
Local heat-air conditioning supply carries contactors.
Grainger contactor with 120V coil and 25 amp capacity across terminals
http://www.grainger.com/Grainger/SQUARE-D-Compact-Contactor-5B129?Pid=search
Fasco H230A with 120V coil and 30 amp across terminals
http://www.cshincorporated.com/product_info.php/products_id/3231
Oct 04, 2010 | Amperite Dayton Solid State Timer On Delay...
I am looking for a Dayton Bench Grinder Manual...more specifically a parts breakout. Dayton Bench Grinder Model 1Z707W. Thanks, Mike
I would try and call Grainger parts to see if they have one. I know they deal with and sell Dayton equiptment. If no luck let me know and I will try and find another source.
Feb 16, 2010 | Grinders
Wiring diagram for a Dayton thermostat
Contact Dayton on the internet for this problem. The diagram should be available on their site. Or they will give you a number for customer care. They can give you step-by-step instructions. I am a technician and this is what I would do as their are millions of wiring diagrams. Many are noy up to date.
Ray
Dec 07, 2008 | Dayton (3E379) Heater
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Dryers Logo
51 people viewed this question
Top Dryers Experts
