Question about Air Tools & Compressors
Head and rod bolt torque on devilibuss model L660V air compressor
emissionwiz
  • 79112 Answers
SOURCE: 2005 Tucson
camshaft sprocket bolt 58-72 ft. lbs. crankshaft pulley bolts 108-132 ft. lbs. crankshaft pulley center bolt 80-94 ft. lbs. cylinder head bolts cold engine 65-72 ft. lbs. warm engine 73-80 ft. lbs. cylinder head rear cover bolts 69-86 in. lbs. flywheel/Driveplate bolts 94-101 ft. lbs. intake/Exhaust manifold nuts/Bolts 11-14 ft. lbs. jet valves 13-16 ft. lbs. main bearing cap bolts 36-39 ft. lbs. oil pan bolts 51-69 in. lbs. oil pan nuts 43-60 in. lbs. oil pan drain plug 33 ft. lbs. oil pump cover bolts 72-84 in. lbs. oil pump relief valve plug 29-36 ft. lbs. oil pump sprocket nut 25-28 ft. lbs. Rear oil seal retainer bolts 84-108 in. lbs. rocker arm shaft bolts 14-15 ft. lbs. rod bearing cap nuts 23-25 ft. lbs. silent shaft sprocket nut 22-28 ft. lbs. spark plugs 15-21 ft. lbs. thermostat housing-to-Engine bolts 86-114 in. lbs. timing belt tensioner bolt 32-40 ft. lbs. valve cover bolts 43-61 in. lbs. water pump-to-Engine bolts alternator brace bolt 14-20 ft. lbs. all others 9-11 ft. lbs. water pump pulley bolts 72-84 in. lbs.
Posted on Sep 08, 2008
heavy389
SOURCE: head bolts torque and sequence
They are listed in all Chilton Repair books,available at any auto store
Posted on Nov 30, 2008
  • 19 Answers
SOURCE: head bolt torque spec for this compressor
220-300 in lbs work from center out
Posted on Feb 01, 2009
  • 701 Answers
SOURCE: torque specs for toyota tercel
Hello vienotkelly: The correct Main bolt torque is 42 foot pounds. The connecting rods torque to 29 foot pounds. The torque sequence for the head bolts and the correct way to tighten the bolts are attached to this reply. Thak You for using6bd0ae1.jpg FixYa. Roger
Posted on Apr 15, 2009
  • 110 Answers
SOURCE: what are the head and rod bolt torque specs on a
one hundred ten inch lbs on the rods and 45 ft on the head bolts
Posted on Nov 15, 2009
Head bolt torque for ir. ss5 air compressor?
It's not that critical, use a torque wrench and make sure they are all evenly tightened like you would do with the head of a car engine. Use basic torque specs for the size bolt. That can be googled. Start with a lower setting on the torque wrench. Tighten the bolts in a pattern, then increase the torque setting and torque the bolts again.
May 20, 2016 | Ingersoll Rand Air Tools & Compressors
Torque on ahead bolt
the torque must use is 75ftlbs. that is for the air head.
hope can help.
Jan 30, 2014 | Ingersoll Rand - Rand Type - 30...
Need to know what torque to apply to the head of the compressor 6HP-60Gal?
I don't find the VT618500AJ model listed in my manuals.
Measure the diameter of the bolt shaft, and find the Grade of bolt. Use the standard torque guide for that diameter, and grade of bolt,
http://zerofast.com/torque.htm
Do Not apply anti-seize.
Install dry. Torque pattern is start with a middle bolt, criss-cross over, and use a spiral out pattern. (Advise go in three stage increments when torquing)
Regards,
joecoolvette
Nov 06, 2011 | Campbell Hausfeld Air Tools & Compressors
Torque specs for the head bolts on a GMC compressor
There are surely specs, but you should be able to feel the right tightness for these bolts. It's when the threads just begin to bend-- if you don't know this feeling, and can't find the torque specs, use 15- 20 ft. lbs.
Nov 23, 2009 | Ingersoll Rand SS3F2 Gm Ir Portable...
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Air leaks between head and cylinder
either the head gasket is gone or the rings are shot
Mar 04, 2009 | Air Tools & Compressors
Head bolt torque spec
220-300 inch lbs work from center out
Jan 15, 2009 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Air Tools & Compressors Logo
83 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
