Question about Konica Minolta Bizhub C364 Color Copier / Printer / Scanner
On a Konica Bizhub c364e, how do you scan multiple pages and have them show up as separate files in your email or USB?
Batch, scan, separate files
    New Friend:
PDF -> Page seperation -> 1 file per e-mail
Posted on Jan 10, 2018
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 79 Answers
Go to Scan/Fax option.
choose your destination.
click on scan setting
on right hand side you will find option SINGLE or
SEPARATE/SEPARATION.
If separate or separation is selected/highlighted thats means all page will be scanned in single file.
if not selected then all single page will create separate file..
Posted on Dec 14, 2016
I am scanning multiple pages at once however I want them to all save as separate pages onto my computer. how do I set this up? It doesn't seem to be working for me.
when you feed multiple pages i guess you are hitting the star button
in order to save them as separate pages you will need to select finish key not the start key this finish key is added with firmware if it is not on your copier already you may need to have a technician do this for you. good luck hope this helps.
Feb 19, 2014 | Konica Minolta Bizhub C224 Color Copier...
Bizhub c450 scans multiple pages to separate scans
hi im lorenzo and i have been fixing konica minolta machines for about 2 years well lets catch to the case.
If you still have problems or cant change to multiple scan.
1.you have to get in the simulation mode because machine doesnt know if the HDD installed is in.
*simulation utilty/counter =details stop 00 stop 01
2. ONCE YOUR IN LOOK FOR SYSTEM 2 AND CLICK ON HDD YOUL SEE THAT HDD IS NOT INTALLED SO CLICK INSTALLED AND THEN EXIT END AND REBOOT THE PRINTER AND TRY TO SCAN AND IT WILL WORK
THUMBS UP IF IT WORK FOR YOU
Jul 18, 2012 | Konica Minolta bizhub C250 All-In-One...
I have a konica minolta bizhub c351 How do I
check in one touch setting, PDF-MMH and MMr, multiple files and single file option, if having problem then call your tech service rep
Mar 29, 2010 | Konica Minolta bizhub C351 All-In-One...
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Merging attachments of scanned files sent by email
You can use the IP Scanner software to scan the documents from your Bizhub to your pc. Once the documents are in your PC you can take apart which pages you want from the scanned documents and save them to another file and e-mail them through your computer that way.
Jul 21, 2008 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta bizhub C250 Scanned files
Try using the Comapct PDF option as a file type.
This should be used if file size is a concern.
It applies a mathematical compression so will affect the quality of the scans very little.
Jul 03, 2008 | Konica Minolta bizhub C250 All-In-One...
Scanning 2 page document
Go into the PDS settings and change tab from single page to multiple page.
Jun 11, 2008 | Konica Minolta bizhub C250 All-In-One...
Scanning a combination of one-sided and two-sided documents
Use the "Separate Scan" button on the panel. By pushing this you are telling the scanner that you have separate scans to scan as one document. Once all files are scanned, push the separate scan button again to indicate you are finished scanning.
Oct 17, 2007 | Konica Minolta bizhub 250 All-In-One Laser...
Konica Minolta Bizhub C364 Color Copier / Printer / Scanner Logo
208 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
