Question about Garden
Size of 0 rings for a hydraulic control for 666 IHC tractor loader
  • Bud H Dec 02, 2016
    Hi Appleby William, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Top Expert:
  • Garden Master
  • 77,939 Answers
Remove the "O" rings and go to any auto parts store to match them up, there is much more than just the diameter, "O" rings come in many different thicknesses.
Posted on Dec 02, 2016
The O ring in the hydraulic pressure valve on John Dere 4720 keeps fail. What O ring size and material spec should I use to stop failures?
Hydraulic pump may be sucking air causing oring to blow out.. Air causes problems when mixed with oil under pressure. Check and tighten all fittings and connections to hydraulic pump. Be sure Full of fluid and filter clean.
Nov 20, 2016 | John Deere Garden
Massey Ferguson 451 has hydraulic issue with lift arms.and loader. When you turn tractor off and back on they work for a while then start again
how old is the hydrualic fluid
any chance of air in the system
if fluid level is ok
will be the valve controls to control pressure and return to the arms
or operator shift stick
Sep 17, 2016 | Garden
Anyone have auxiliary hydraulics layout particularly where/how its plumbed into control valve
PDF]2013 Skid Steer Loader Parts - - All ...
Auxiliary Heaters . ... Hydraulic Lift Cylinder . .... Service Manual - Tells you how to take the skid steer apart, how to fix it, and how to put it back together ... in the serious repairs or restoration, you need the shop service manual; It can give you many ...Bobcat. 520, 530, 533. 122571. $48.00. Bobcat. 500, 600, 610. 122521.Missing: layout ‎plumbed ‎into
[PDF]PARTS REFERENCE GUIDE - Service Motor Company
HITCH PARTS. 125. HYDRAULIC PARTS ... Find the same heavy-duty quality builtinto Case IH batteries for your truck ... lawn and garden tractor, Case IH has the ... Whether it's off-road, lawn and garden, automotive, or marine application, look ...... 12 Gauge. Aux. Lead, 3/8" Eye with B- Splice 12". ZQC708101. 4 Gauge.Missing: layout ‎plumbed ‎1977 ‎clark ‎520
Massey Ferguson Tractors Information - SSB Tractor Forum
What hydraulic fluid is needed for a Massey Ferguson 390 · MF135 Selling ...... Hydraulics quit working after installing Aux Hydraulic control valve. MF 135 lift
Case Farm Tractor Parts and Manuals - Yesterday's Tractors
Dec 12, 2015 | Garden
Rear link arms wont lift under load. what can I do to fix this?
you didn't mention make or model; rear links are hydraulic?
If so did your "mechanic" put a high pressure gauge on the ram hose(s) and see what pressure there was? Problem could be in controller for link.
Jun 06, 2015 | Garden
My rear hydraulics on my 1979 case 1370 tractor
Sounds like you have a hydraulic cylinder bypass problem on the disc
May 09, 2012 | Diesel Case 1370,1470,1570 Tractor Piston...
Ford 770A loader hydraulics lift cylinder shaft won't move.
Hello there:
when you dissconnected the hoses did you turn the cylinder upside down and let it drain cause some hydraulic lift assybelies have a small chamber in the head of them that retain fluid and with out removing the fluid it will do a hydraulic lock and wont be able to move untill you losen the bleeder screw if it has one ok please let me know how this goes for you
Sep 10, 2009 | Garden
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Mar 26, 2009 | Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
