Question about Kenmore Washing Machines
What year was kenmore washer model 1102011200A serial number CL3204433 made
maklean
  • 1665 Answers
SOURCE: Kenmore 90 washer won't drain
Check first drain line or water pump to see if they are clogged.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump.
Posted on Jan 14, 2008
SolutionGuy
  • 331 Answers
SOURCE: What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
Posted on May 02, 2009
bozcro
  • 867 Answers
SOURCE: Kenmore dryer will not heat
only 2 things can be wrong, the heater element is toast or one of the safety thermostats is fried, most likely it is the heating element. make sure its well connected(while unplugged!!!)
Posted on Jun 14, 2009
  • 1937 Answers
SOURCE: kenmore (Inglis) washer leaking oil model
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
See the Whirlpool parts list for their commercial washers, the consumer model is essentially the same.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The problem is likely either the transmission cover or the gearcase cover seal or the spin pinion seal.
Following is a good description from GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
When you pull the transmission, you should be able to tell where it is leaking.
In order to pull off the cover, pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 16Oz of oil
Posted on Sep 22, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore Washer Model 110 Serial Number #CF2915758
The following link explains how to determine the date of manufacture for a Kenmore:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
Thank you for providing your serial number. According to the information I provided, your washer was manufactured in July of 1996. Kenmore is manufactured by Whirlpool so this advice does apply. If you have any questions, please let me know. I hope this helps you.
Posted on Mar 24, 2010
Testimonial: "Thank you very much for the information and your prompt answer. Great Service. Thank you."
How do i find the year of my sears washer
Your Kenmore is a Whirlpool.
Therefore, you need the serial number to determine the year. The second digit in the serial number is the year code.
You can find the lookup table here:
Determining the Age of Your Whirlpool Appliance
Oct 21, 2014 | Sears 4.5 cu. ft. Top-Load Washer
What year was my kenmore washer 110.26442502 made?
need both the model and serial number,go to appliance411.com and look up your model,it will tell you the year of any appliance.
Jun 27, 2014 | Kenmore 24032\24036 Top Load Washer
What is the age of my kenmore dryer model # 110.66662500?
The age of the appliance is determined by the SERIAL NUMBER. Kenmore, which is manufactured by Whirlpool uses the format described in the following link:
The 2nd DIGIT in the serial number determines the YEAR it was manufactured. The next two NUMBERS after that digit represent the WEEK (52 weeks in a year) it was manufactured.
If you have any questions as to how to determine the date based on your serial number, please post back and let me know. I hope you find this information helpful.
Aug 25, 2010 | Kenmore 43142 Front Load Washer
What year is this model number?
Hi
You'll need the serial code to check for the year, the serial code is located on various locations. Please check this picture to search for your serial number--
After you find the serial number you can calculate the month and year of the washer by checking this coding list--
Code list for finding the year of manufacturing
Please post back for any further assistance.
Daniel
Jul 25, 2010 | Kenmore 98702 Stacked Washer/Dryer
Hello, information request (birth date)
The manufacture date is determined by the SERIAL NUMBER on the appliance. The serial number should be located along with the model number on a nameplate along the wash tub rim under the lid. Kenmore washers are manufactured by Whirlpool. The serial number format is explained in the following link:
The second digit in the serial number will represent the YEAR in was manufactured. The first two NUMBERS following that second digit represents the WEEK (52 weeks in a year) that it was manufactured.
If you locate the serial number and still need assistance in how to detemine the age, post back and let me know. I hope you find this information helpful.
May 31, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I'm trying to find out how old my mothers wash machine is. The model numbers in 2270
The date of manufacture is determined by the SERIAL NUMBER on the appliance. Since Kenmore washers are manufactured by Whirlpool, the following link explains how to determine how old your washer is:
The serial number will be listed on a nameplate along with the model number along the wash tub rim under the lid. The second DIGIT in the serial number identifies the YEAR it was manufactured. The first set of NUMBERS following that digit represent the WEEK it was manufactured (52 weeks in a year).
If you need help determining the date, please post back with your serial number so I can assist you. I hope you find this information helpful.
Mar 29, 2010 | Kenmore Washing Machines
HOW CAN YOU TELL YEAR OF WASHING MACHINE
The date of manufacture is determined by the SERIAL NUMBER on the appliance. If this is a Kenmore washer, it was probably manufactured by Whirlpool. The following link explains how to determine the age of an appliance manufactured by Whirlpool:
The second digit in the serial number represents the YEAR it was manufactured. The first two numbers after that digit, represent the WEEK it was manufactured (52 weeks in a year).
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: For future reference, please post a MODEL NUMBER and/or SERIAL NUMBER when submitting questions to get quicker and more accurate responses.
Feb 20, 2010 | Kenmore Washing Machines
What year was the 110.28812790 washer made?
The dates of manufacture are determined by the SERIAL numbers on the appliance. The following links explain:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
Your Kenmore is manufactured by Whirlpool. The first two numbers in the serial number identify the WEEK it was manufactured. The digit preceeding the first set of numbers, identfy the YEAR.
http://www.fixya.com/support/r2880528-determining_age_maytag_appliance
On Maytag models, the last two letters in the serial number determine the date of manufacture. The first letter is the YEAR, the second letter is the MONTH.
Nov 11, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer dryer age?
The age is determined by the SERIAL number. If you post back with each appliance serial number, I can tell you what year they were manufactured. Include any letter designations that are in the serial number too.
Jul 23, 2009 | Kenmore 600 7965 Dryer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
