Question about JVC Televison & Video
I need to know if I could use my dell ax510 soundbar it's for a monitor but I want to use it for my Jvc tv instead but it's got a pass though cable & a jack plug please can you help me
2 Suggested Answers
SOURCE: Problem with Dell AX510 Soundbar
in order for your sound to work you have to disable the on board sound in the bios . unless you already did the , then i would return it and get a different one.
Posted on Apr 20, 2009
How do I replace sound bar on monitor?
Deb Powell,
Reverse the steps listed below. They are for connecting the sound bar.
1. Working from the rear of the monitor, attach the Soundbar aligning the two slots with the two tabs along the bottom rear of the monitor.
2. Slide the Soundbar to the left until it snaps into place.
3. Connect the Soundbar with the power brick.
4. Plug the power cables of the power brick into a nearby outlet.
5. Insert the lime-green mini stereo plug from the rear of the Soundbar into the computer's audio output jack.
NOTE: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only.
NOTICE: Do not use with any device other than Dell Soundbar.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 16, 2016 | Dell E197FP LCD Monitor
How do I connect my ht ct260h step by step, with hdmi input do I use
HDMI can be a bit confusing when first connecting a system. Overall, the HDMI cable system allows for less clutter and digital audio and video, but you need some background to get it right.
The simple answer to your question is that the HDMI on your TV that is labeled HDMI out will go to your soundbar's HDMI input. Now, the reason you have a picture but no sound, will be one of 2 problems. If your TV is labeled with ARC, this means that it has an HDMI with Audio Return Channel and will be compatible with your CT260h soundbar. If you don't have sound, then you need to replace your HDMI cable with a ver1.4 HDMI cable so that ARC is supported in the cable design. If your TV does not provide ARC, then you will need to connect the audio using the digital optical connection which is a fiber optic cable of the TOSLINK variety. This cable should have been included with your soundbar packing.
Also be aware that if you buy a HDMI1.4 with Redmere technology to save on the size of the cable, it has a direction for the signal flow which must be adhered to, otherwise the cable will not pass either audio nor video.
I hope that answers your question.
Feb 16, 2015 | Sony HT-CT260H Soundbar and Wireless...
How to connect soundbar to a TV with a skybox
Connect the soundbar either to the TV's optical output. Or use an Optical to stereo phono/RCA converter box and then a pair of stereo phono cables (red & white) to the soundbar.
If it's a very basic soundbar with just a headphone jack input then you can go from the TV's headphone output instead.
As for the Sky box, just leave it connected via either an AV lead or better still a HDMI cable direct to the TV. The TV will send sound out to the soundbar.
Sep 04, 2014 | Televison & Video
The Dell AS501 doesn't seem to want to connect to my Dell E196FP Monitor.
If there is a power connector for the soundbar, it should be on the bottom of the monitor where all the other connectors are located.
Mar 25, 2014 | Dell E196FP 19" LCD Monitor
How do I connect an itrak soundbar model #bt0218m0 to a hitachi1080 tv model #na92172
Most HDTV's do not have an "Audio Out" connection, because they're usually not the thing producing the sound. You probably have a cable box and/or a DVD or blu-ray player, which is then plugged into the TV. You need to keep the video part of that plugged in, but unplug the audio and plug it into your soundbar instead. You will probably need some form of adapter, though I don't want to go into that too much without knowing what your setup is.
Nov 10, 2013 | iTrak Encore 32" 2 Channel Bluetooth...
My Dell AX510 Soundbar Speaker isn't working, although the blue light is on, indicating it has power. I'm using a Dell monitor that is set up primarily for Playstation usage.
Ensure that the sound is actually supposed to be coming through the speakers. Just because the power is on doesn't mean that audio information is actually on it's way to the actual speakers. Maybe the television volume is low or muted, maybe the output volume is being routed somewhere else, or maybe the soundbar is broken. You should investigate and follow the signal to find the problem.
Sep 29, 2013 | Dell Ax510 Ax510pa Soundbar Sound Bar...
I have a 4.5" black strip running down my 2001 fp monitor screen. What do I need to correct it.
Note: Soundbar Power Connector - 12V DC output is for optional Dell Soundbar only. .
DO NOT USE WITH ANY DEVICE OTHER THAN DELL SOUNDBAR.
  1. Working from the rear of the monitor, attach Soundbar by aligning the two slots with the two tabs along the bottom rear of the monitor.
  2. Slide the Soundbar to the left until it snaps into the place.
  3. Insert the black DC plug from the power cable at the back of the Soundbar into the DC Jack on the back of the Flat Panel Monitor.
  4. Insert the lime green mini stereo plug from the rear of the Soundbar into the Computer's audio output jack.
Jan 16, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Apr 20, 2009 | Dell ADA745 Computer Speakers
Have a dell flat panel pc monitor, want sound. the only thing i see is speaker power?? whats this for?
the monitor has the ability to attach a sound bar (AX510) the power connection is for the add on speakers
Jan 28, 2009 | Dell E173FP 17" LCD Monitor
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
