Question about Bosch Saws
My bosch 4100 lost power and the blade started running backwards. what went wrong and what parts do I need to order to fix it?
    Top Expert:
  • Bosch Master
  • 48,245 Answers
For an electric motor to run backwards it requires a current direction change in the fields
as that is not possible unless there is a direction change switch as in a reversible drill there is a major fault in the motor windings
take it in to an appliance repair shop for a proper diagnosis and quote
Posted on Dec 01, 2016
What causes my bosch 4100 saw to run slowly backwards
sounds like a 3ph saw that is single phasing in the wrong direction..need some more details of your saw...
Jul 12, 2014 | Saws
Bosch 4000 table saw motor does not turn, very stiff
Possibly something has jammed inside the motor housing although unlikely.
Electric brake seized perhaps?
Carbon brushes need replaced?
These saws (and the newer 4100) have a history of motor problems, with the field winding and electronic motor speed control being the most common points of failure. If you go to an online tool parts supplier like toolpartsdirect- Bosch 4000 saw you will see a list of the parts available, as well as the most commonly ordered parts.
Thanks go to Jason for his blog post at:
May 23, 2014 | Bosch 4000 - 07 Electric Table Saws
Why is the blade on my black and Decker edger spinning backwards and how do I fix this
if its spining backwards the blade is up side down motors dont run backwards they run clock wise your blade should run clockwise to its possible they put your blade on backwards you will hgave to flip it put it back on
May 18, 2014 | Garden
Blade on table saw will not raise
typically this is a thrust washer issue. need to look at the play between raise and lower..also ensure trunion is cleaned and lubed.
Dec 27, 2013 | Bosch Power Tools Bosch 4100-09 Worksite...
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
Electric blade brake sounds like it is seized up. Upon starting table saw (bosch 4000), motor sounds like it is binding. How can I disengage the brake??
There is no electric brake on the Bosch 4100 table saw. If the motor sounds like it is being held back its possible the rear armature bearing has seized or the field coil is faulty. Both these problems cause the motr to not turn at full speed. The motor must be serviced.
Dec 08, 2010 | Bosch 4100 10" Worksite Table Saw
The saw wants to start backwards.
this confuses me. What do you mean it starts backwards? How do you know it is running backwards? how long have you had this tool? I am confused because it is a table saw. The motor should drive the blade in the direction the teeth are facing. Meaning the poity part of the blade is where the wood is to star its cut. If this is not the case, you either have the blade in backwards, or your standing on the wrong side of the saw. good luck.
Mar 04, 2010 | Bosch 4000 - 07 Electric Table Saws
Saw slowed down. Shut off saw and restarted. runs backward.
Sonmethings shorted out inside motor / strip and see if any debris is in there.
It has somehow repolarised from the negative side to pos side!!
Jan 20, 2010 | Bosch 4100 10" Worksite Table Saw
Bosch 1581 old style, blade is tightened with a screw driver. The screw to tighten the blade is lost. How to get part for an old style saw or have it repaired?
go to and you can order online or find a Bosch center near you the part number is 2 603 400000 and it lists for 1.20, let me know if you need more assistance.
Dec 30, 2009 | Bosch Saws
Having trouble removing the motor from the bosch table saw. i have removed the four black screws from the black housing but it does not want to seperate from the aluminum housing. it will turn seperate...
tilt the saw head and then use a screwdriver to gently pry apart. the bearings in the housings are keeping it from coming apart or the armature and or field are melted causing this, either way the screwdriver trick will work.
Dec 07, 2009 | Bosch 4100 09 10" Worksite Table Saw...
Saws Logo
127 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
