My Seeburg LPC-1 starts but the record picker upper just spins by the disc and doesn't engage to pick up the record - it just stopped working one day - any ideas what's wrong with it
    New Friend:
  • 13 Answers
Check the worm and motor that moves the tray back and forth and see the slider mechanism
Posted on Dec 03, 2016
I have a Seeburg Select-O-Matic jukebox, model M1000, doesnt scan or move only spins, what could be the problem?It doesn't pick up the record or move at all, just spins.
I think you mean a Seeburg M100C
This is known as the "sit and spin" The main clutch is not shifting properly. This is a lubrication issue. the old grease has become glue like and is gumming everything up. The main clutch is located between the record rack and the record mechanism. Spray the s**t out of it with WD40 you may have to let it soak over night or take the record rack off. Don't remove it unless you have to. make sure that you blast that clutch (see pi of clutch) The thing at the thumb needs to move up and down freely. it work on gravity!!!
DO NOT REMOVE THE CLUTCH AS PICTURED
Remember you will need to spray through the record rack to get at it, so you will need a good flashlight to see it.
Make sure that the trip lever is not sticking. the can be gotten to easily. 24614542-gg2ae1cwkykr1dpptmtggk30-2-2.jpg
These pic may look slightly different from your C but the mech is basically the same. The trip lever in the pic is at rest. yours is likely up at an angle. Try raising it up or down after spraying.\
Once you get it moving again make sure you oil the piont with liquid bearings or other quality oil. Because WD40 will not keep it going it will gum up again if you don't oil. Do not over oil. it has a way of getting between contact that it's not supposed to. AND keep using it every day for a while.
Seeburg M100C
m100c-02.jpg m100c.jpg Ed.
Jun 11, 2014 | Wurlitzer Jukebox 1015 One More Time...
One day my ac stop working, ac clutch doesn't engage but it is not froze, it still spins
Chances are you may have a low pressure relay that shut it off. Check the pressure and add more r34 if its low on coolant.
Aug 01, 2013 | Cars & Trucks
How to coat ptfe on upper finger of photocopier
Sir/Mam, there is no coating on the upper fuser pick fingers they are just replaced
Jul 03, 2013 | KONICA MINOLTA 4002578303 PICKER FINGER...
I have a LPC 480 Seeburg Jukebox that scans, pick up the record, the needle touches the record, then returns the record to the carriage without playing. What can I do?
Try reading this, basically the fault can be in the mech, the amp or trip switches.
http://www.flippers.com/Seeburg-trblshoot.html
Nov 28, 2010 | Audio Players & Recorders
Seeburg jukebox sx 100 scans twice and returns
I suggest that you go to the following site for a solution to your problem.
The information listed hereis second to none.
http://home.pacbell.net/fmillera/
Regards
Alan Hood
ami-man
UK
Oct 13, 2009 | Wurlitzer Jukebox 1015 One More Time...
Seeburg AY160 Spins as if record in place. will not reject.
Try removing the mechanism cover (power off). Turn it back on and try lifting the manual trip lever just to the right of the tonearm. This will cycle the mechanism. If it cycles but still won't engage and scan down the track, your clutch is stuck from lack of lubrication. Consult the manual, which you need to have. Try eBay - several people seel good reprints.
This is a common Seeburg problem and can sometimes be fixed IF you can get some oil into the clutch. Otherwise, you'll need to take the clutch tower off and that's best left to someone with experience.
IF you want to attempt it, you MUST have the manual as you'll have to set up and re do a bunch of adjustments after taking so much apart.
Jul 22, 2009 | Wurlitzer Jukebox 1015 One More Time...
Mechanism will not pick up records
Check out the tormat on your jukebox. It runs almost the full length of the mechanism. On the tormat is the A and B side contacts and a ground rail. You will see that on the mechanism is a arm that runs over these contacts on it it has very fine wire links (similar to those on motor brushes) these can become disconnected and may require being resolderd back into place.
Regards
Alan Hood
ami-man
UK
Jan 17, 2009 | Wurlitzer Jukebox 1015 One More Time...
152 people viewed this question
 Grubhead
Grubhead
