I have a comfort 2000 thermostat. It seems to be working fine, but every once in a while it makes a loud clicking noise. Does it need to be replaced?
SOURCE: Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Posted on Jan 27, 2007
daverh
  • 117 Answers
SOURCE: Makes a loud humming noise while operating
Almost certainly, the component called the "magnetron" has died. This is the valve (tube in the US) which actually generates the microwaves. The loud humming is the transformer that supplies the magnetron being overloaded and/or the magnetron itself. If the rest of the appliance is OK and not too old, the magnetron can be replaced. If you aren't familiar with these appliances, you *must* get this done by someone who understands the dangers of messing with them - if you get it wrong, they can bite! In some countries, only qualified engineers can buy the spare parts. In the UK, the part costs around £40 - £80, depending on the model. If the appliance is more than around three years old, it may be a false economy to repair it as other parts may fail soon after the repair.
Posted on Sep 24, 2007
  • 4 Answers
SOURCE: washing machine making a clicking noise.
The problem most likely is something stuck in the water port of the drain pump. My machiine would not empty once and I found a 12 penny nail that had made its way from the drum though the drain line to the the pump, where it was wedged against the impellers that spins to draw out the water through the pump. The pump is located in the front right bottom of the machine and accessible by reoving the lower front panel, It is held in place by 4 small screws and is connected to the drain lines. Disconnect the plug for the outlet, then disconnect the power connection from the pump. Disconnect the drainlines after removing as much water possible from the drum as the water will come out of these liines when you remove them. Remove the pump, open the cover to see the impeller and hopefully the bobby pin, nail, screw, or whatever else is stuck there will be visible and easily removed. Put the pump cover back on, replace the drain lines and screws, and reconnect the power connection to the pump. Then do a better job checking your pockets.
Posted on Jan 24, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
SOURCE: 2000 watt baseboard heater is making loud clicking noise
Most base board heaters installation instructions say to attach to the wall with screws which are slack ( not fully tightened) in order to allow the heater case to expand and contract otherwise you get a clicking noise
Posted on Oct 31, 2008
Makes a loud noise
needs new bearing kit ,it will collapse soon,
Apr 09, 2014 | Bosch Nexxt 500 Dryer
Loud popping noise after click of thermostat
Clicking noises are normal...banging noises are not. Replace the thermostat.
Dec 15, 2013 | Honeywell Heating & Cooling
Brakes have been squealing off and on, but now has sudden loud scraping noise while driving
Brake shoes/pads worn out. Replace now. Be careful dangerous situation
Aug 13, 2017 | 2000 Suzuki Grand Vitara
How to change a starter motor on a 2000 Buell CycloneM2?
The loud Click click click isn't because the starter is bad it is because your battery doesn't have enough power to kick it over. Change your battery. The click will stop. Harley starters either spin without making any click noises or don't make any noise when they go bad.
May 02, 2012 | 2000 Buell M2 Cyclone
Loud Rattling Noise While Running
That's the blower fan blade loose on the motor shaft making the noise. Once you replace that the noise should clear up. You don't provide the make and model so I can't give you a part number, but you can Google search for "replacement fan" for your specific model. Sears' parts site (www.searspartsdirect.com) is a good place to start. Enter your model number and they have exploded views and parts information for most models. Then you can use the information to shop around. There are many online vendors for appliance parts.
There are also several websites showing the steps for getting into the dryer to replace the part. Replacing the fan blade is not a difficult job to do yourself if you are comfortable with a screwdriver and have a little mechanical aptitude. Otherwise an appliance technician could repair this for probably an hour labor charge plus parts ad trip fee. Certainly less than a new dryer would cost.
Apr 29, 2009 | Dryers
99 Grand Prix Heater only works on 5 makes a Loud noise
hi there
it sounds to me that you have two problems the
loud noise is the heater motor bushings is worn out causing the loud noise and vibration
also you will have to replace the resistor
once the motor is replace and the resistor replace all should be ok
don
Mar 09, 2009 | 2000 Pontiac Grand Prix
Turn the key get a loud clicking noise no start
soildoid is damaged on starter.after a few attempts to start it it may start tho
Jan 15, 2009 | 2004 Ford Expedition
Loud pulley noise coming from A/C unit?
it sounds like the bearing is going bad in the pulley through chrysler i believe you have to replace the whole unit. to do this you will need to recover the freon from the system which makes it hard to do at home
Dec 02, 2008 | 2000 Jeep Cherokee
Nov 17, 2007 | Heating & Cooling
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
