Can I hook up using only 2 speakers - Audio Players & Recorders
    Top Expert:
  • Audio Player... Master
  • 78,010 Answers
Yes you can.
Posted on Dec 01, 2016
Can you have just 2 channel by hooking up to right & left front speaker posts on 5.1 surround
short If you hook more than one speaker up to a single channel, it will lower the impedence and will damage the amp. You can hook up multiple speakers by using a speaker switch box between the speakers and the amp. This will match the impedence and should keep the amp from blowing.
Dec 21, 2014 | Panasonic Technics SA-G76 AV Control...
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
If i hook up for 2 ohm do i use one speaker wire off amp bridged
Just use both speaker outputs, no need to bridge them,
Jan 25, 2012 | Hifonics BRZ17001D Car Amp
I'm trying to hook up using 2 little rca speakers, for L/R i've set the reciver to 2 speaker setup and for some reason i can't get sound from my speakers. any ideas? I've got HDMI from a Samsung DVD player...
If the amplifier supplies a different resistance rating (ohms) than the speakers draw, it might automatically shut down the amplifier to protect from damage. Make sure the Teac output matches the speakers required input. Hooking up speakers that draw 8 ohms to an amp that supplies 2 ohms can cause amplifier damage.
Sep 28, 2009 | Teac DC-D2800 Shelf System
Wonding can you hook up 4 8omhs speakers to a dual center channel. rear plate on amp says 1 speaker 8 omhs min 2 speakers 4omhs min there are 4 posts in back if i hook up 2 8omhs speakers in parral to both...
You are correct
spks in p = lower than the rating of one
spks in s = greater than the rating of one
so 2 x 8ohms in p = 4ohms
and 2 x 8ohms in s =16ohms
Make sure that you do not connect too many speakers to the amp, and try to stay as close as possible to the amps specs.
Hope this helps, thanks for using FixYa
Sep 24, 2009 | Onkyo TX-SV727 Receiver
Stereo display works fine, but no sound to speakers.
The wires may have gotten wet and fried something in the sound output in the stereo.
Jun 16, 2008 | Pioneer DEH-1900MP CD Player
Adcom GFA-5400 installation
Use the niles for more than one speaker hookup. As far as the sub hookup, use a powered sub with speaker inputs
then use the right or left speaker and tag a couple wires to the sub. Good Luck
Dec 28, 2007 | Adcom GFA-5400 2-Channel Amplifier
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Multiple speakers in same outlet
How this reciever is set up is there are left and right A and left and right B Only one 8 ohm speaker should be attached per outlet. if you exceed that your driving the channel at a much lower resistance then the units designed for and the channel will burn up.. Oh it might last a short time but bet your last dollar it will burn up the channel if you over load it. Please dont forget to rate this.
Oct 15, 2006 | Pioneer VSX-454 Receiver
29 people viewed this question
