Question about Vacuums
Ihave a canister vac. Bought last april low suction
Vac.i bought it last april. I routinely clean the filter, check tunes and openings for leaks and blockage. I also check roller for strings. Yet I have poor suction. The loss starts just after I replace canister
    Top Expert:
  • Vacuums Master
  • 79,189 Answers
Have you cleared the vacuum hoses
Posted on Dec 01, 2016
Filter queen vac 2 years old suction poor cleaned hose canister and filter
Hi, Did you change both the cone and the filter on the top lid? If so, ther may be a leak in the machine breaking the air tight vacuum. When you put it together make sure its in properly and tight. Let me know if this does not help, I will look at something else. Chris
Feb 09, 2011 | Filter Queen Majestic Canister Vacuum
Upright positon dyson won't work
Have you checked your permanent filter? Have you checked the hoses for clogs. As a last resort you can disassemble the cyclone and clean it. If the vac is less than 5 years old, Dyson will probably send you a new Cyclone to replace yours.
Also check that you have the gasket inside the center of the bottom of the clear canister on the right way. If it is backwards your suction will be much less
Jul 10, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
Is there a second filter
You have not posted a brand, however central vacs with an internal hanging `self cleaning ` filter seldom contain another filter with the exception of Eureka or Kenmore which may have a secondary optional paper filter installed. Check the bucket and the gasket first. Eureka and Kenmore made by Eureka are prone to a defective gasket which disintegrates with wear. The bucket should sit snug on any unit with no play.
To test for proper suction check at the vac intake itself. If the suction is strong here and weak elsewhere your problem will be either a clogged vac line, a leak in a pipe or an inlet door sagging open, last of all a clogged or partly clogged hose.
Check your hose by dropping a coin through the handle and shaking it down to the other end. If a coin makes it through your hose is clear.
You can test each inlet with a numbered tissue and your hose. Mark one for each inlet and check the tank to see what made it through. If any fail to make it through, go to that inlet with another vac and draw the blockage backwards out the inlet. Then retest
Also listen for a hiss at each inlet with the hose plugged in elsewhere. The hiss indicates a leak behind the inlet in the wall. Check for worn seals or misaligned o rings in the backing plate where the inlet connects.
Last of all inspect the pie for possible cracks from impact . If you listen closely you will hear an audible echo along the pipe path (even within the wall) if a connection has separated or a pipe is damaged.
Please post back with what you find or if you need more help.
Oct 13, 2009 | Vacuums
Ridgid 16.5 gallon motor running with no suction
When you use the shop vac for cleaning up water you must remove the filter.
The filter is for dust particles not for water
I would replace your filter and dump the water out from the shop vac, Also after each time you vacuum up water dump it out of shop vac.
I hope this helped you happy new year!
Jun 30, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Lost suction
TOSS IT and forget it! I have never used a hand vac that worked that was worth the effort of turning it on .... I suggest they are all junk ... I found very few vacuum cleaners ... actually **** especially anything made by dirt devil ... I do have a bagless Bissell 6579-2 that I purchased 4 years ago at walmart for $49 ... It outperforms any vacuum I've ever used, including my worthless Shop-Vac that I paid a lot more for ... this Bissell vac SUCKS ... It could **** the barnacles from a steamship!
Apr 28, 2009 | Dirt Devil Vibe AllPurpose Hand Vacuum...
I bought a Kenmore canister vacuum, model 116, in April 2007. This morning, the sound of the motor suddenly began to deepen, and I began to lose suction. Normally, if something is clogging the hose, the...
Okay, bear with me. Is it possible you have a suction adjustment, dial somewhere on vac. Check and see and if it does, be sure it's all the way up. Also, try removing hose and run a broom handle fr. one end to the other...BUT be careful not to stretch or break hose, they cost BIG BUCKS.
Jan 17, 2009 | Vacuums
Little suction in craftsman canister style carpet/floor cleaner
you might have a leak on the suction side...perhaps the housing is not properly secured, or there is a **** in the black plastic hose.
Sep 10, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
We have a Kenmore Stylite Retrax vacuum cleaner, brand new. Suction is not working properly.
I actually pulled back my old vac after using this thing. Having said that I have played around with it and one quick cure is the remove or clean the little circle sponge filter at bottom. If you remove the canister and look at the bottom of vac you will see where the air travels down through a small circle. In there is a sponge filter that is probably clogged. Now Being frustrated, I just removed it and the vac sucks like crazy now. There are just way to many filters to worry about. As mentioned you need to clean the top main filiter, then the top sponge filter, and then dont froget there is alson one in the front of the machine (square paper filter) that catches dust leaving vac. These are on top of the little circle one that I removed, so I dont think it will be missed. Try and see what you think.
Apr 21, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
