Question about Exercise & Fitness
Treadmill making squeaky noise but not in belt, seems to be in the base, any suggestions, if i put alot of pressure on the handles it seems to stop momentarily.
    Top Expert:
  • 8,095 Answers
Why does my Treadmill make loud squeak with each step take ShopYourWay ..not saying this forum will help you out but it might point you in the right direction
Posted on Dec 01, 2016
It's making squeaky noises and the area where the long bolt where the handles are seem to have loose washers how do it get it loose to put on new washers because it won't unscrew.
Try soaking them with WD 40 and spray where the squeaky noise is coming from with it ,might be just be dry and in need of lube.
Oct 03, 2015 | Area Exercise & Fitness
When I get on treadmill it slows down andjust about shuts off. Im 265 pds, My wife gets on @ 160 pds the treadmill runs fine. I ADJUSTED THE BELT LOOSER AND IT STILL RUNS THE SAME. WHAT CAN I DO TO CORRECT...
Loose is not the answer. Proper lubrication and correct tension adjustment is the answer. I don't know how many HP the motor is for, but for 265 pds it should be at least 3HP.
Put the speed at about 3MpH and while walking, make a small jump on the belt to ensure that it is properly tensioned. Needless to say that the belt must be well lubricated. If you see that the belt tends to stop when you make the jump, turn both allen screws exactly the same amount clockwise. Half a turn might be enough. When you're satisfied and the belt doesn't seem to stop, give both allen screws another half turn clockwise.
All that as long as the treadmill is capable of handling your weight.
Jan 17, 2014 | Proform XP 580 Trainer Treadmill
9500 hr belt stops when stands on it and funny noise from machine , noise stops when adjust front tension bolt but belt still loose
see the video and proceed. This happen because the lack of maintenance schedule . If the problem remain after you did LUBE is time to replace the old board belt. God bless you
Apr 01, 2013 | Life Fitness Used 9500 HR Treadmill
Squeaky sound
LUBE inmedIATELY the deck belt +rollers bearings too. If the problem persist time to replace the complete deck belt board.
God bless you
Jan 08, 2013 | Nordic Track NordicTrack Powertread 5.5...
The belt is tracking to the right side. I tried to adjust it using the hex key, but that seemed to make it worse. Also, when running, the seems to stop or jar under my feet. The motor makes a whining...
It sounds like you have a bad bearing. If you are not familiar with repairing/replacing bearings on a treadmill, I suggest you contact NordicTrak and have a tech come out and repair it.
Jan 06, 2011 | Nordic Track NordicTrack A2750 PRO...
When I turn on the treadmill, after runinng for a few seconds, the belt makes a squeaky sound, as if it needs to be oiled up or needs adjustment. What can be done to fix this? Any suggestions are greatly...
The best recommendation and the most inexpensive would be to lubricate it. Do not use a silicone spray or anything with silicone in it. You should us a waxy lubricant or teflon based. Most specific treadmill lubricants suffice. If the sound is coming from the front of the machine then I would check the drive belt that goes from the front roller to the motor. These are 90% the causes of the sound. Lubricating and tightening generally corrects the problem.
Aug 15, 2010 | Proform 5.0 Crosstrainer Treadmill -...
I have a 6 year old Reebok RX5000. At speeds
They walkbelt is most likely worn out causing too much friction overheating the motor.
Jan 15, 2010 | Exercise & Fitness
Weslo pro tread belt
Hi, Yes it is! the belt is not free floating but travels on a slide. When there is pressure on it ( from someone) it rubs on the slide underneath. When you step off it should stop the rubbing noise. There you go, this should Fixya!
Mar 24, 2009 | Weslo Pro Crosswalk 7.8 Treadmill
Squeaky noise when turning
Check your power steering fluid level
Feb 14, 2009 | 1992 Daihatsu Charade
Squeaky noise from belts.
nissan has an updated belt tensioner and it will also get a new belt.
Jun 06, 2008 | 2005 Nissan Pathfinder
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
