Can I replace my microwave which is whirlpool but it's continuing working after 25 years so I want to replace it
My whirlpool is not as good as the Daewoo kor6l15 and I want to make it stop working I want it to stop working it's working for longer than I want it to I want to replace it with the Daewoo kor6l15
Re: Can I replace my microwave which is whirlpool but...
You don't have to wait until it is no longer working. Donate it to Salvation Army, Rescue Mission, etc. if they'll have it. Otherwise dispose of it and buy the one you want.
The F6 code is listed as a problem with the MW relay. Here are the testing steps from the technical literature. The relay that is mentioned is a part of the control so if the problem continues you will need to replace the control. 1. Unplug microwave oven or disconnect power.
2.Check the cable to Relay 4903.
3. Check to see if the relay (4903 on relay electronic control) contact has welded closed.
4. Replace all parts and panels before operating.
5. Plug in microwave oven or reconnect power.
6. If problem persists, unplug microwave oven or disconnect power.
It certainly sounds like something is wrong. My first GE microwave was like this and it wasn't advertised as anything special. After a long life I replaced it with a Sharp (makes most all microwaves) and was disappointed at the cycling on and off. Now Panasonic makes what they call Inverter microwaves with continuous power. I recently bought a GE (probably made by Panasonic) with this Inverter technology and am very pleased with it. Make sure the microwave you have says AccuWave on it, if it does, it sounds like the magnetron may have been replaced with a non-continuous type of magnetron. Was it bought refurbished/returned/clearanced? I think when I was researching this that it MAY have something to do with the type of power supply to the magnetron and not so much the magnetron itself.
If the microwave control panel doesn't light up, then your fuse is blown. unplug the microwave. unscrew the vent grill, (2) screws at the top of the microwave. then you should see 1 screw holding the control panel. after removing that screw, gently push up then out. there should be a metal plate on top of the control panel. remove that plate and the fuse will be in that opening. remove the fuse and check for continuity across the fuse. Replace fuse and microwave should begin working.
I'm assuming you mis-typed and meant the oven begins running when you SHUT the door and stops when you OPEN the door. Please tell me this is what you meant! If the microwave oven runs with the door open, UPLUG IT IMMEDIATELY AND DO NOT USE IT!!!
If the oven begins running without pushing the start button then the controller is bad or the Start button is worn out and making contact without pushing it. (Most likely it is your controller.) Generally, it is not worth the cost to replace the controller on a 10 year old microwave. Probably time for a new one.
But if you want, you can call Whirlpool and see what they suggest at 800-253-1301.
If this was helpful, please select YES to the first two RATINGS questions. Good Luck!
just aquired one just like it for free. they said no heat. took the outer cover off. about 12 screws. pull the main fuse and test it with a continuity tester.thats probably not it if the lights work. its either the magnatron (toshiba 2m248j(gs) or replacement part amana 8205460. mine was a coroded magnatron connection.unplugged it and pluged it back in. heats fine now. if you left it on with nothing in it for any length of time you blew the magnetron. universal magnatron replacements on ebay are $25. 4 screws and a 2 prong connector.
First, there is an outlet. Plug in something else. Inside the key panel, there are fuses and a thermo sensor. Either may be bad. The thermosensor is about the diameter of a dime, black and 3/8 inch thick...attached to the wall of the chamber. All should have continuity.
