Honeywell ST7100 control unit had a flashing battery light. Replaced batteries unit not come back on
    Top Expert:
  • Heating & Co... Master
  • 40,558 Answers
Your thermostat may have to be set up for operation again.
Posted on Dec 01, 2016
Why would the drivers side window control unit stop working and alternate flashing light after replacing the old battery with a new one.
the memory was probably erased when you replaced the battery, check your manual on how to program your windows.
Oct 24, 2014 | 2011 Toyota Camry LE
I have a honeywell cm927 control unit, and the red light on the receiver keeps flashing. i can manually turn the boiler on and off at the HC6ONG receiver. i've tried the faqs in the manual but to no joy....
The red flashing light means that there is an issues with the RF comms between control unit and receiver. You can reset by switching the boiler off and back on and then re-sending the temperature signal. You need to check batteries in you thermostat and also the position as the signal could be interfered with or it may be too far away from the receiver.
Sep 25, 2010 | Honeywell Programmable Thermostat Heater
I replaced the battery to honeywell RTH230B. Heat won't turn on.
I followed a comment from a previous source and reversed the polarity of the batteries. I then flipped them back to the correct position and the flashing battery indicator went away and the thermostat functions correctly.
Feb 04, 2010 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
How to change battery on honeywell st7100 and what type of battery do they use. thanks
Pull the unit straight out and away from the wall. It is plugged into the baseplate. The batteries are behind or among the 30 pieces in your hand and on the floor,,,, AH! Just kiddng, you wil see the batteries on the backside.
When pulling off use gentle rocking as you pull. You will see why when it is off. To reinstall, just line up the oinds and press in place.
Oct 27, 2009 | Heating & Cooling
Honeywell T8411R 1028No power to the thermostat; breakers are not
site shows this thermostat is a non programmable unit and has been discontinued. none of the info sheets including a pdf shows a replacement battery. this thermostat operates off line voltage only. check for a control fuse or breaker on your heating unit.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
Flashing battery symbol
I had this same problem today.  I called Honeywell and they said the flashing broken battery symbol may mean low batteries, or it may mean the battery type is incorrect.  They recommend only non-rechargeable alkaline batteries.  I was using rechargeable NiMH batteries.  Even though they were fully charged, I had the flashing battery symbol and the thermostat relay would not work.  I replaced with alkaline, the flashing battery indicator went out, the thermostat works again.
Odd that it worked for 3 months on the rechargeables after first install. I did notice the broken battery symbol came on after the first few days, but I checked the battery charges and they were good, so I disregarded the symbol until the thermostat stopped working today.  Apparently there is something about the NiMH performance characteristic that the thermostat doesn't like.
Jan 31, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
76 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
