Question about Home
I have a atomix clock which I cannot change the time zone?
informatica
  • 1114 Answers
SOURCE: Time zone
Hi - You can download the manual from the link underlined in blue below:
Chaney
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2008
SOURCE: change time zone
To change the time zone press and hold the time zone button until the number after the Z in the display flases and then release the button (number will still be flashing) and then press the same buttoon and you will see the Z number change to the zone you need. The zones are printed on the top of the clock under the top lid that pops up. My problem is we are in daylight savings time and I cannot get the Eastern Time zone to let me "spring ahead one hour" for daylight saving time!
Posted on Mar 10, 2009
SOURCE: Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Posted on Apr 04, 2009
SOURCE: setting time zone
found manual--
Remove from email listing and send no further communiques.
Posted on Nov 01, 2009
gopakumarg43
  • 75424 Answers
SOURCE: Had to change the batteries in the Atomix clock and now the
Hello
What is the Brand name and Model number of your Atomic clock?
Posted on Jan 04, 2012
Setting time smartset
I couldn't figure out how to change the time zone because I didn't have the manual. Here's how to change time zone:
1. On top of clock you hold down time zone button
2. Push the up or down button to change the time zone. There are 7 time zones. The clock is set at zone 2 -Eastern Standard time. My zone is 3 -Central Time - I then had to manually set the correct time -(I'm not sure why but I did that) To test if the time zone worked properly I switched the time zones and the time on the clock adjusted automatically to the associated time for that area. I, of course, moved it back to zone 3 and the correct time for central time was displayed. I am waiting to see if the time properly adjust when time the DST changes. Also, for the manual: http://www.emersonradio.com/owner_manuals_list.php?ID=157
This is the manufacturers website (Emerson) for the EZ Set clock radio. Hope this helps.
Oct 03, 2013 | H.H. Scott SCR120 Clock Radio
Hello
Jan 04, 2012 | Audio Players & Recorders
I can't set the day.
You have to set the Year. Hold the time Set until the hours blink then push the time set button again and the minutes blink then push the time set button again and the year will blink. Change it to 09. Then push the time set button again and set the date.
Mar 26, 2009 | Chaney Instrument 13130 GM Atomix Digital...
Time zone
Chaney
Aug 13, 2008 | Chaney Instrument 13130 GM Atomix Digital...
Daylight savings time again
Appparently the problem could be with your location, or just that there may be a delay before time correction until the old date - check again the link to amazon i posted before - there are a couple of new reviews that discusss the daylight saving issue, also - The US clock says; "I have a radio controlled clock that receives NIST time. Will the new rules affect me? Your radio controlled clock should automatically implement the new DST rules. The WWVB broadcast contains information that tells your clock whether DST or ST is currently in effect. NIST always sends this information to agree with the current DST rules, so your clock should change automatically on the day of the change, just as it has in previous years. If the time is wrong after the DST change, make sure that your clock has recently received the time signal. Many radio controlled clocks have a synchronization indicator that will tell you if your clock has recently synchronized. If the clock isn't receiving the signal, click here for some tips on improving reception. If it has received the signal recently, check to make sure that the clock's time zone setting is set properly. Also, if you live in an area where DST is not observed (Arizona, for example), you need to disable the automatic DST function on your clock. I have a non-radio controlled clock that used to automatically correct itself for DST. Will it still work? The only way to find out is to wait and see, or to contact the manufacturer of the clock. There are a large number of non-radio controlled clocks, marketed under names like "AUTOSET" or "SMARTSET" that have internal firmware that automatically changes the time by one hour on the transition days to and from DST. These clocks do not connect to a NIST time service, and some of them will no longer work properly due to the DST rule change. For example, clocks manufactured prior to the rule change will probably not switch to DST in March, but will wait until April in accordance with the old rule. If you have a clock like this that fails due to the new rules, your only recourse is to adjust the clock manually, or to contact the manufacturer and ask for an upgrade or a replacement. If you need to contact manufacturer check http://www.emersonscott.com/ezsetamclocr.html Hope this helps:)
Mar 11, 2007 | H.H. Scott SCR120 Clock Radio
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
