Question about Amazon Fire TV Stick
I have a fire tv connect to my tv the problem is this all time the cc are on how take off.thank you
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Closed Caption keeps coming back on
When you turn it off are you going into the setup menu to do this?? if so after it comes back on and you go back to the menu and you see "on" You will need to save your settings before you exit out of the menu
Feb 17, 2008 | Televison & Video
150 cc will not fire up
pull spark plug, lay it on engine while still connected and hit starter and see if any spark at plug. if so fuel issue,if sat for any lengthy period of time, pull carb. float bowl and clean bad fuel and resadew, unscrew brass looking jet and make sure clear,{should be able to blow air thru} ensure battery has full charge and should fire.
May 26, 2013 | ATVs
I have samsung tv and de comcast cable,but i try to put the close caption and isn't work,can you help me please
closed caption can be blocked by the cable box- make sure cable box is set to allow closed caption.
on the TV, makes sure CC is set to CC1.
be certain you are on a Closed Caption program...all PBS stations are Closed Caption, all the time.
Apr 13, 2011 | Televison & Video
Vizio 42" LCD. Flat screen. Won't display CC on setup screen using HDMI input. Have a Sharp tv on another Directv box and it shows CC via HDMI connection. Problem with receiver or with TV? Costco's "Help"...
CC is a feature of the TV. All TVs are different in features and the Vizio is limited on its features due to cost. To eliminate the directv receiver connected to Vizio TV just swap with the receiver connected to Sharp TV and see if CC is displayed.
Mar 05, 2009 | Vizio VO42L 42 in. LCD TV
I have a philips magnavox tv with the original remote. closed caption constantly (writing script)comes on tv screen, even though the remote has a cc button,i press it until cc off comes on, the cc goes off...
You're not doing anything wrong. Your TV is somehow turning the cc on "all by itself". Some bit is getting flipped inside the TV, turning the cc on.
either that or there is some sort of rf or ir interference near the TV that is mimicking the CC button on the remote.
Have you pressed the cc button on the remote, verified the cc is "off" on the TV and then removed the batteries from the remote for a while to make sure there isn't something hinky with the remote???
Feb 27, 2009 | Televison & Video
Can't turn subtitles off
I want to thank whomever suggested the works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Closed captions
Closed Caption may only come on when you have the television muted.
Mar 10, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Amazon Fire TV Stick Logo
51 people viewed this question
Top Amazon Televison & Video Experts
john cordey
john cordey
Thomas Stauber
Thomas Stauber
Ron Harvey
Ron Harvey
Level 1 Expert
Are you an Amazon Televison and Video Expert? Answer questions, earn points and help others
