Question about Honda Electrical Supplies
Honda igx440 remote start - Honda Electrical Supplies
I have a 2013 Honda Accord with push start and ever time i unlock the car and open the door after it is remote started it shuts off. Is there a fix for this?
Yes, you must have the remote start reprogrammed, probably can only be done at dealership if factory or by the installer if aftermarket.
Jan 22, 2016 | Honda Cars & Trucks
I have a coolstart remote starter on my 2005 Honda Accord and recently my battery died. After replacing my battery the remote start would not start the car. The engine cranks but does not start.
Need to bring back to whomever installed remote start for them to reprogram the remote start. Seems it needs to be re mated to cars system.
Jan 02, 2016 | Honda Cars & Trucks
How to start your car the alarm wont allow it can you fix it yourself
How to Disable Car Alarm - YouTube
? 1:13
Feb 14, 2013 - Uploaded by Blog Ternet
... how I permanently disabled the car alarm on my 2001 HondaCivic 2 door coupe. ... My alarm remote broke and im not able tostart it now ... 2005 ford ranger ... up or remote start you will completely disable your car/truck until you go ... I have'nt started my car since January. the alarm is on & it won't shut ...
Alarm and remote not working but still locks - Honda Civic Forum > ... > 7th Generation Civic
Dec 6, 2009 - Hi I have a honda 2002 Civic EX with a factory alarm. ... From a 2001-2005 Civic alarm manual, the situation you describe, where the dome ... FYI, to putyour car in valet mode, you do the same proceedure, all within 3 seconds. .... Remote part works, but the car won't start (green key light), PinkCupcakes ...
Honda Civic Alarm(need to disable) - Honda Civic Forum
Jan 01, 2016 | Honda 2005 Civic LX
1996 honda 160i luxline remote imobilzer programing
reset immobiliser I HAVE A HONDA CIVIC 1.6 LUXLINE ...
Jan 22, 2014 - reset immobiliser I HAVE A HONDA CIVIC 1.6 LUXLINE 1998. I NEED TO BYPASS THE IMMOBILSER TO START THE CAR WITHOUT IT ... Press any button on remote one time within 20 seconds. .... How can i fix my honda 160i luxline92 model starting difficulty? Jul 20 ... Jun 09, 2012 ' 1996 Honda Civic.
Sep 27, 2015 | Honda Cars & Trucks
Why does my honda generator cut out after 20 seconds?
either you have a crankcase with low oil or overfilled and contaminated with fuel.fill oil to first thread of filler and try again,if overfilled by fuel then you need to clean the carburetor float it may be obstructed.if oil okay and continues to shut off you may have a faulty low level sensor.
Jun 23, 2014 | Honda Electrical Supplies
I've just got a wireless remote for my Honda 6500 ,after pressing the arm button and then the start button I hear a click but no start
I have the same remote start but I could never get it to work so I just gave up . I hope you find the solution I would like to use mine .
Dec 03, 2013 | Honda Generator Wireless Remote Start Kit
Civic, encoded key, will remote start work?
A key has to be inplanted in the steering column inorder to install a remote start. Thats the only way to do it my friend. Good luck and thanks for using FIX YA
Apr 03, 2010 | 2001 Honda Civic
I have a 2004 honda accord and recently the remote wont start the car.the remote will crank the engine but does not fire. will start just fine with the key.
after market remote start sounds like control unit bit the dust(aftermarket control unit not ecu) or wiring to distributor from remote start has a short somewhere
Oct 10, 2009 | 2004 Honda Accord
1997 Honda Civic: Battery died and the Alarm won't disable
If you hook up the jumper cables can you disable the alarm with the remote?
Jun 24, 2009 | 1997 Honda Civic
Electrical Supplies Logo
168 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
