Question about Hotpoint Dryers
Hummin noise hotpoint TDC32P dryer
Hi ive changed the thermal fuses on my hotpoint aquarius TDC32P dryer which would click when pressed "start" but only a low humming could be heard, thought must be heating element so ordered and replaced that. now its exactly the same clicks like its trying to go when u press start but only a low humming can be heard, nothing else happening? any help please?x
    Top Expert:
  • Hotpoint Master
  • 77,939 Answers
That noise is usually associated with a failed AC motor that turns the dryer drum.
Posted on Dec 01, 2016
Testimonial: "ah balls! have tried the other options ive read for simular problems rotating the drum myself with the door hinges pressed in, the timer lights up now and then when i turn it but dont think i want to spend more momey on parts if its not the right solution :("
  • 1 more comment
  • yadayada
    yadayada Dec 01, 2016
    I can only guess based on my experiences, sorry no 100% solution.
  • Jackie Marsay
    Jackie Marsay Dec 01, 2016
    thank you for taking the time to try helping out :) much appreciated i might just go kick the hell out of it and pray that helps lol x
  • yadayada
    Great idea.
I have a Hotpoint Aquarius condenser dryer model number tdc32p serial number 28101317. Is this a recall tumble dryer please
call ge they'll know i think it's 1-800-gecares look at the model tag or manual to find number
Feb 06, 2018 | Hotpoint Dryers
Hi I just replaced the element on my hotpoint aquarius it work fine for about 10 minutesthen just went to cold air I checked the element and it seems fine what else could cause this to happen.
Check your thermal fuse. Also, the upper limit thermostat could have taken a nose dive. Another culprit could be the centrifugal switch on the motor, but that's pretty rare. Also, make sure your vent hose and venting system to the outside is clear of any obstructions. That's usually the reason why elements and thermal fuses burn out.
Oct 18, 2014 | Hotpoint tcm570p Aquarius Condensor Dryer...
Spinning drum
yes it does have belt can you turn drum in side by hand if yes and belt hasent broke must have come of pully belt should be tight on drum
Sep 13, 2013 | Hotpoint TDC32 Electric Dryer
No heat
Check on the back of the drum for a thermal fuse or relay. Common fault on tubledryers is no power to heating coils becuse of blown fuse or most likely the relay to heating coils is dirty. have to be cleaned about every 2/3 years depending on use.
Aug 09, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint aquarius washer dryer wd63 1100 spin - my fuse went just as i was switching the machine on - so the door locked and wont open - changed the fuse, door was still locked so thought id let the wash...
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jan 22, 2009 | Hotpoint Aquarius WD63 Front Load...
No power??
It's more than likely its the door lock, if not check the timer contacts on the top front connection block, if they have blown it will need a timer & door lock
Nov 02, 2008 | Hotpoint Aquarius WD63 Front Load...
Aquarius WD645 - dryer has stopped heating up
there is a safety device to prevent overheat. this can be a resetteble stat ie with a little button in the middle - press this button and there may be a little click as it resets. dryer will then work.
other type of safety device is a thermal fuse. this will be mounted on top of the dryer duct inside a sleeve. test for continuity and if open circuit, replace it
Apr 21, 2008 | Hotpoint WMA46 Front Load Washer
Changing the thermostats on a TDC 32 P
your stats are at the back of the dryer take the metal cover off at the back u should see your stats straight away the cover should be the one that sticks out more than your back casing m8
Aug 27, 2007 | Hotpoint TDC32 Electric Dryer
Dryers Logo
42 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
