1978 Rockola 470: arm picks up 1st record and puts it on turntable. Plays. tries but does not return it to carousel. picks up the next record and puts on top of the other record. Very slowly done.
5 Suggested Answers
CykoMF
  • 3 Answers
SOURCE: rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Posted on Sep 16, 2008
  • 42 Answers
SOURCE: Record will not play to end.
There is a mechanism underneath the deck which senses "end of record". This is operating too early and will require adjustment.
Posted on Jan 25, 2009
MechMusicSF
  • 16 Answers
SOURCE: Record return arm doesn't go low enough to pick up record
Lubrication issue. Use some light oil (NOT 3 in 1 household - it has paraffin and will eventually clog up the parts) on all of the arms moving parts.
Be sure to get in between the gears and the moving cylinders that clamp the record.
This should resolve it. Rock Olas are known for this issue. The original grease dries up, and people neglect to lubricate their jukeboxes, even though, like a car, they are machines that require it from time to time.
Posted on Apr 18, 2009
  • 8 Answers
SOURCE: I've recently picked up a Pioneer Plx-88z
Check the auto trip lever which should return the arm back to it's rest after the end of the record.It has possibly been advanced.Is this a belt frive or direct drive turntable?
Posted on Jun 06, 2014
Turntable arm will not lower - the guide just pushes it back to the off position
Try to do this
1. unplug the turntable
2. raise the arm
3. put it over the record
4. lower it which will not lower you said
5. push the arm to the very end close to the label
6. rotate the turntable by hand and it should take it through the whole return cycle of the arm and lower and finish the motion
7. then plug in and it should come back to normal
Dec 26, 2016 | Audio Players & Recorders
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Picks record ,clicks twice ,returns record without playing
Mechanism for moving arm over and onto record is fubar. Probably stuck and the clicks you hear are the motor fighting a losing battle and returning arm to rest mount.
Remove stylus and play with arm and simulate turn on cycle to see how it works and where the jam is- fix and then put stylus back in - those little suckers are expensive.
Dec 06, 2015 | Audio Players & Recorders
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
I've recently picked up a Pioneer Plx-88z turntable second hand. I know that the player is working ok as putting the arm on the record plays music. The problem is that after a few seconds, no matter what,...
Hi, if it's a second hand device. there must be something wrong with the arm at it's moving axe. if something (dust or broken support) is blocking it, it will return automatically to its rest position to avoid any damage to the fragile and sensible "head"
Jun 02, 2014 | Audio Players & Recorders
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Apr 12, 2009 | Video Game Consoles & Games
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Dec 30, 2008 | ION Audio TTUSB10 Turntable
Rowe ami jukebox
Jun 09, 2008 | Audio Players & Recorders
123 people viewed this question
 Grubhead
Grubhead
