Question about Toys
Why does my e300 so slow dose not move under weight
My E300 runs for 15 minutes get's slow rests then runs again what wrong???
it will run slow for 40 mins at a slow speed, after 15 mins of running fast, the batteries get too hot
Apr 11, 2016 | Razor E300s Electric Scooter With Seat
How do i slow down my 1920 1930 seth thomas matle clock. i tried slowing with the key but it doesnt slow down. it gains about an hour in every 12 hours
I wish I knew the name of the parts but here we go. On the swinging pendulum on your clock there should be a sliding weight on the bar. This will have a set screw or a thumb screw that you can loosen and slide the weight up and down to change the pace of the pendulum. Down is slower and up is faster.
Jan 18, 2015 | Seth Thomas Audio Players & Recorders
Why washer moves and vibrates all over when spinning
There must be the correct weight in a washing machine. If it is under loaded then the drum will spin out of balance because the weight is trapped to one side. regualar use like this will break the drum bearings.
Weighty things like towles & sheets have to be balanced around the drum prior to spining, that's why the drum does slow and quick spins to even the load out. apart from that one of the drum supports need attention.
Oct 03, 2014 | Washing Machines
My e300 razor run but will not move
Check to see if the chain is moving when you apply throttle. If the chain is not moving but you can hear the motor working then it is likely the chain has come off the motor sprocket. If this is the case then follow the steps in the user manual to refit the chain and adjust the tension.
Aug 12, 2014 | Razor E300 Scooter
JVC turntable AL-E300 turntable slowing down when tone arm moves iacross
Even if the belt looks fine it's almost certainly the problem. You mentioned "cleaning" - if you got any kind of fluid on the belt it might act as a lubricant and reduce the friction between the belt and the drive wheel, causing the turntable to slow when the tone arm puts a drag on it. The problem may go away when the belt dries out.
Nov 23, 2013 | Audio Players & Recorders
Why is my jerkin why i going the speed at 30mph if I go faster its fine.
could be a wheel imbalance. you may have thrown a weight. also on front wheel drives the is a weight on the drive shaft, if that has moved or added weight/or lost weight it can make an imbalance at slow speeds.
Oct 11, 2013 | Ford Cars & Trucks
What to do when it moves slow
either you charger or your battery is bad, chaeck the charger to make sure that its putting out enough volts with a multimeter, then visually inspect the batteries for bulging
Apr 29, 2012 | Razor E300 Scooter
Where is the battery on e300 97' model
The C- Class (202 chassis) has the battery in the trunk, the E- Class (210 chassis) with the round head lamps has it under the rear seat.
Jan 12, 2009 | 1998 Mercedes-Benz E-Class
Toys Logo
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
