Question about Makita Saws
Makita ls1013 blade change - Makita Saws
    Top Expert:
  • Makita Master
  • 8,204 Answers
LS1013 Sliding Arm Saw. Why doesn't it turn on when trigger is depressed?
The trigger may have simply failed. Usually failure occurs at the least convenient time or circumstance.
Sep 05, 2015 | Makita Saws
How do I view the owners manual on line for a Makita LS1013 sliding miter saw
I have attached a link with the parts breakdown and the owners manual both in PDF format.
The parts breakdown should help you, if not let me know and I'll try to talk you through it.
Makita Products Tool Support
Mar 11, 2015 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita LS1013 110V feels underpowered. What could have caused this? Brushes are barely worn.
How underpowered? running at half speed? If so check the wiring in the 110v plug. I have seen saws come into the workshop where 1 of the wires is connected to earth pin this results in 55v being fed to saw hence 1/2 speed. Is there heavy arcing at the commutator? if yes armature probably blown. If not still worth examining armature for discolouration, examine field coils at same time if everything seems ok then a possibility is the controller. You could try by passing the controller and if saw seems to run better then you know you need a new controller. It is located at the back of the motor. If you are not sure about electrics do not try this you may electrocute your self or blow the controller.
Feb 21, 2014 | Makita Saws
How do u change out bushes on a makita ls1013
there are 2 black screw caps on the outside of the tool that need to be removed. USE a good quality blade and right size to avoid chipping the caps. UNPLUG TOOL first and remove the old ones and replace with new and reassemble. They might arc for a short period of time depending on the commutator wear. Run at NO LOAD for about 10 minutes. Let me know if you still have a problem
Apr 05, 2012 | Makita 10" Dual Bevel Sliding Compound...
My LS1013 saw head is in the down storage position and will not raise up. It is not pinned.
you need to depress it fully to disengage the lock. If the head does not depress enough there is a screw that you would need to loosen on the left hand side to allow for the head to travel lower. Make sure there is nothing under the blade to affect movement before trying bolt.
Jan 23, 2012 | Makita Saws
How do I replace the spildle that the blade attaches to
The above link, is a complete exploded parts diagram. Below is a generic How to replace the spindle & bearings.
You will need to lock, the spindle, and use a puller, and maybe even heat to get it apart depending on how worn damage etc?
below is a wiki for another type but may help?
A spindle repair service below.
Apr 11, 2011 | Makita 10" Dual Slide Compound Miter Saw...
How to remove guard and blade on LS1013
Theres a nut on the guard you need to loosen. Guard will then open enough to change blade. if you want to remove it completely theres a phillips srew you also need to remove.
Jan 24, 2011 | Makita 10" Miter Saw LS1030N
Hi all I have a Makita LS1013 that I got from a friend. I am trying to repair the switches in the handle as they are blown. I have the replacement parts I need to do the job. However someone seems to have...
gdoran681, The information I sent you should have the wiring you will need. Let me know if you have just the LS1013 or if it has the lights on it (LS1013FL)
Rob Popp
Phoenix Repair
Nov 09, 2010 | Makita 10" Miter Saw LS1030N
I need step by step on putting blade guard back on Makita LS1013
Go to and in the header type in your model number and just follow thru till you can download a parts breakdown with exploded view of the guard. Just lay parts out in the order you see them and its not hard to reassemble. Might I ask what happened to guard? If you stilll have problems let me know and I will help. If I have helped you with your request would you please rate this response accordingly. Thank you.
Sep 12, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Makita LS1013FL manual missing
Yes go to and type in your model number and you can download an owners manual for the tool. Let me know if you need any more help
Feb 15, 2009 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Saws Logo
538 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
