Question about JVC Watches
Jvc em65ftr lcd tv has sound but no pic. Not sure what part I need or how to find it
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
42 in LG LCD TV turns off by itself
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
LG LED LCD TV-I had no sound and a black screen, replaced the main board, still the same
IT is not wise to attempt repairs on LED TVs. They rarely work, and you end up replacing the unit anyway. The newer units have the LED drivers connected directly to the LED screen and there is no way to repair/replace them. Board swap/replacement is tempting, but overall the lost time versus the cost is often not worth it. Sets today are only designed to last 3-5 years. The manufacturers use the minimum rated electronic parts to ensure failure and thus a steady stream of replacement buyers. Some don't even make it out of warranty, but the manufacturers are willing to risk the cost in order to ensure that the planned obsolescence continues. Gone are the days of a set lasting 10-12 years or more. Take that into consideration when buying a replacement and only get what you need. Buying newer features that are not in full use yet only costs more and by the time you get the benefit of them, its time for another new set.
Jan 13, 2016 | LG 47LV4400 47 Class LED HDTV - 1080p,...
I can't get the tv to have the surround sound work
This effect varies greatly from one set to another, it may only barely perceptible.
Dec 25, 2014 | Sony DAV-TZ140 Home Cinema System Home...
How do I turn off the starting sound on a Samsung series 7 tv?
On your Samsung remote. Press the MENU button. At the botttom of your screen you have the setup selections. Scroll over to the SOUND option and select that, A menu should appear and toward the bottom of the menu you should see MELODY. Scroll down to that and select ON or OFF...
Nov 02, 2014 | Samsung UN50ES6500 Series 7 LED 3D 1080p...
Battery replacement for G Shock AWG-M100
Sounds like someone has replaced the rechargeable cell with a regular silver oxide of the same dimensions. Normally this doesn't work as the rechargeable cells have a part of the connector welded to them and normal cells don't. If you can source the rechargeable cell they are relatively easy to fit you just have to make sure the connector on the cell goes into the righ tplace on the watch.
May 31, 2014 | Casio awg-m100-1a g-shock awg-m100-1aer
My G-Shock is changing colors uncontrolably
mcdevito75 here, Sounds like the LCD, liquid crystal display may be going bad on you or hopefully the battery is weak and needs to be changed, look for a small watch repair shop in your area and have your Casio watch checked out.
Oct 16, 2010 | Casio Watches
No sound
Make sure the sound is turned on the unit. Press and hold the lower left button for a few seconds and you should see a little Sirus like pic on your watch. If you have that and no sound then you have a problem. Maybe try taking the battery out and reinstalling after a few minutes. If nothing works then your choice would be to send the watch to get repaired or live with it. The heart rate does flash if you are under or over your target rates. Good luck
Jan 24, 2008 | Polar M32 Heart Rate Monitor Watch
Watches Logo
19 people viewed this question
Top JVC Watches Experts
Ansel Alberto
Ansel Alberto
Are you a JVC Watch Expert? Answer questions, earn points and help others
