Directions for changing thermocouple in a 1985 intertherm furnace robertshaw gas-fired igniter
  • Janice Arn Dec 01, 2016
    Don't know why this question is under air conditioning. Should be mobile home intertherm furnace
  • Paul Carew Dec 03, 2016
    On the gas valve there is a grey nut this is the connection of the thermocouple undo this .In your picture it shows the thermocouple there should be a hex head behind the thermocouple undone this it may just pullout , Hard to see from the picture might be a little fiddly but simple to do
  • Heating & Co... Master
  • 2,600 Answers
Look in the comments I put a answer there yesterday by mistake .
Posted on Dec 05, 2016
diths_kri
  • 67 Answers
SOURCE: furnace blowing cold air
THERMO
Posted on Jan 07, 2009
meBNme
  • 334 Answers
SOURCE: weak flame in intertherm furnace
Ok, so we can rule out the ignitor. (standing pilot systems can develop problems that will cause such symptoms.)
Check the gas pressure, make sure you are getting 11 to 14 PSI.
You need that after the regulator all the way to the manifold.
Also check for cracks in the heat exchanger, causing the wind from the blower to distort the flame pattern enough to cause improper contact with the flame sensor.
Make sure the burners and flame channels are clean of rust, and dibri build up, allowing the flame to properly contact the sensors.
Posted on Jan 19, 2009
meBNme
  • 334 Answers
SOURCE: intertherm gas furnace inducer centrifugal switch
Chances are the draft inducer motor is not pulling enough CFM through the heat exchanger.
That is usually due to either blocked/clogged flue pipe/vent.
damaged, missing or dirty fan blades.
or a motor going bad.
Check those three things first, as they are the usually problem. Other than that, it would be a sticking or bad switch.
If you s-uck on the end of the hose like a straw, while it is attached to the switch and it does not pull in then you are looking at a bad switch/cracked hose issue. If it does, then you are back to the draft inducer motor or it's squirrel cage fan being bad.
These are notorious for rusting and the blades breaking off.
Posted on Oct 03, 2009
  • 587 Answers
SOURCE: Intertherm MGHA-075BFC-01 gas fired furnace - air
Probably the limit switch is open.
Posted on Oct 16, 2009
  • 89 Answers
SOURCE: Intertherm MGH-056ABFC-91 won't kick on. Just
There is probably more than one limit switch. I'll have to get a wiring diagram of this unit. See if you can follow the wires from the wires from the limit switch and see if they go to another limit switch. Also you can put a jumper wire on the red wire and white wire on the unit outside and see if ti comes on.
Posted on Nov 03, 2009
Intertherm gas furnace in mobile home..igniter comes on then nothing tries to fire byrners but nothing
by igniter I assume you mean the thermocoupler. are you turning the control button to run after you light the pilot light? Normally when those furnaces quit it is the thermocoupler that has quit. Get a new one and leave it in the furnace compartment as a spare.
Jan 06, 2015 | Intertherm Heating & Cooling
Pilot light won't light
Will it initially light, then go out when you release the button?
If yes, then change/adjust the thermocouple or pilot size.
If no, then check that you have a gas supply, that the igniter is sparking, that the gas valve is allowing the pilot flow through.
Apr 06, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm propane furnace will not stay on
your machine is missing the oxygen check your ventilation,
1. try to turn it for 1 minute with leaving the door open.
Mar 24, 2014 | Intertherm Heating & Cooling
INTERTHERM NO HEAT OR BLOWER
This could be failure of the igniter and/or thermocouple.
Jan 27, 2014 | Intertherm 56000 Btu Gas Furnace
Intertherm furnace M1BG wont fire
Make sure the gas valve is turned to the ON position after you had it in PILOT position. Also check the thermostat low voltage wiring @ furnace...jumper the Red & White wires to bypass the thermostat temporarily. Make sure there is 24 volts on you low voltage circuit.
Dec 16, 2013 | Intertherm P3RA-048K Air Conditioner
My pilot flame goes out after a short while and the gas shuts off then as it should. Why does the pilot flame cut out so rapidly?
Because she ain't gettin confirmation of ignition.
Your flame sensor is contaminated most likely.
Get a dry brillo pad and clean that dude. Give it the alabama gloss and the mississippi shine then reinstall and retry.
I have 2 links. Old school RobertShaw kanthal Spark/sensor notes and Auto cycling furnace easy fix.
Let me know dude!
Mar 16, 2011 | Heating & Cooling
I have a intertherm furnace 60000 btu inlet,
Souns like the thermocouple is gatting weak and needs replacing!
Dec 20, 2009 | Heating & Cooling
Intertherm furnace problem?'s
the blower on my furnace keeps going on and off when i turn the furnace on .ichanged the snapdiscs no change changed thermocoupler and therostat still no change whats my problem
Oct 27, 2007 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
52 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
