Question about Freezers
I have a Artic King 5.0 chest freezer. How long do you wait before you put in food. Does it have an outside light
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
SOURCE: Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Posted on May 01, 2009
  • 20 Answers
SOURCE: Kelvinator chest freezer not freezing
SUM HUSBAND. call the handyman N-E-WAY
Posted on Jun 09, 2009
nnesmith
  • 162 Answers
SOURCE: Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
Posted on Jul 26, 2009
SOURCE: i recently bought a norfrost chest freezer model
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
Posted on Feb 26, 2011
Where can I get an Artic King 7cf chest freezer food basket and manual.
Need exact model number a picture of data tag on freezer would be the best send to appliancetech40@gmail.com
Feb 05, 2017 | Freezers
I have a Kenmore 5 cu ft freezer that won't come on. I've checked the plug in and it works fine. Where would I start looking for the problem????
If, by plug in you mean the socket, then you need to check the fuse in the power plug next.
At the very lease there should be some light on the unit that illuminate even if it does not FREEZE.
If the compressor comes on wait to see if there is any drop in temperature. then it is possible the fuse was faulty.
see below links for more information on possible causes
How to fix Kenmore chest freezer model 255 19502010
Kenmore 5 cu ft 142 liter Chest Freezer 14512 Page 11 Recent Questions...
Jul 18, 2015 | Kenmore 5 cu. ft. / 142 liter Chest...
QWhy won't magic chef 6 cubic chest freeze freeze anything after I defrosted it?
Try plugging something else in the outlet. A lamp would work to make sure you did not trip a circut breaker when you plugged back in after defrost.
Apr 23, 2014 | Magic Chef 5 cu. ft. / 142 liter Chest...
How long does it take to cool before putting food into it
i would let it run for about an hour then stock it. this is what we recommend after servicing
Jun 05, 2010 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
May 29, 2010 | Freezers
I have a chest freezer that i want to place outside but need to l
fridge/freezers are designed to operate at plus 10c to 35c .a shed will just about do but will not work at its best.have you thought about a " lean to " to store your freezer in.do NOT drill hole in freezer walls.
Feb 21, 2010 | Freezers
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Freezers Logo
74 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
