I need to replace a 2200 simple comfort thermostat what # replaces it
4 Suggested Answers
  • 74 Answers
SOURCE: thermostat reset???
after you changed the battries did you check the set point. it is also possible that the batteries have ruined the stat
Posted on Aug 30, 2009
SOURCE: i need to know what
my window air conditioner is making alot of noise and it is blowing alot of water out through the front vents. It doesn't matter what mode I am in. Can this be fixed or do I have to get another one?
Posted on Jul 31, 2010
  • 1515 Answers
SOURCE: I need a diagram to
Posted on Apr 11, 2011
My simple comfort 2200 thermostat has a brown wire hooked to the e terminal. what is the e terminal for?
Likely for emergency heat. When the heat pump is in defrost mode, due to extremely low ambient temps, e is your indoor heat strips.
Jul 02, 2017 | Heating & Cooling
I'm looking for a thermostat to replace my simple comfort 2200 it has 7 wires across B O W2 G E Y1 Y2 and 3 wires vertical R C L I'm looking for a thermostat to replace wire for wire. can you help??
What you have is a 2 stage cool/3 stage heat pump compatible tstat. And I'm guessing by the info you provided that the wires "across and vertical" are 2 sets of wires that are running inside the wall to your indoor unit. As if they didn't have enough wires and run an extra. We normally run 1 control wire with 5,8,10.or12 wires inside. And there should only be a wire connected to B or O, not both? Again I'm guessing. If I'm correct, then any "2 stage cool/3 stage heat" tstat that is "heat pump compatible" should work. I'm also assuming that you have wires connected to B or O. Now if you have a wire connected to both B & O, best call out someone to change it for you because that's different than I've ever seen. Also, the L is a wire used from the outdoor unit, and sometimes both indoor and outdoor, to communicate with the thermostat when something's wrong. Most multi-stage tstats will have this but you'll need to check/ask before you purchase if you want this feature. Also, after you install, be sure to configure the new that to match your system. Hope this helps!
Mar 06, 2017 | Heating & Cooling
Simple comfort thermostat
most thermostat are plus or mines 5 degree for turn on or off
Jan 29, 2018 | Cars & Trucks
Simple comfort 2200 thermostat not working properly
We have a Simple Comfort 2200 Electronic Thermostat and last night it quit blowing cool air and the # sign beside the air temp (the set to temp) starting blinking
Aug 11, 2012 | Heating & Cooling
Thermostat reset???
Aug 30, 2009 | Heating & Cooling
Switching thermostats
The two wires are the control circuit from the heater your running. They go to the thermostat and close when it get below the thermo. setting and start the heater.
Jun 28, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
