Question about Panasonic Lands Phones
Panasonic kx-tg5566cm cordless phone
I fully charge the phone and could be just within an half an hour it says link not close enough to base and i lose all signal . its been happening alot lately . any answers
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
  • 192 Answers
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
Posted on May 01, 2009
SOURCE: i have problems the no link to base with Panasonic
  • Press and hold the LOCATOR/INTERCOM button for the extension that is displaying "No Link To Base" on the Base until a beep sounds.
  • Press and hold the FLASH/CALL WAIT button on the Handset that is displaying "No Link To Base" until a beep is heard.
  • When registration is complete, a beep sounds from the handset.
  • Wait for 20 seconds after registration is complete to allow the handset to establish communications with the base.
If this doesn't work or it keeps happening, replace the battery in the handset.
Posted on Jul 08, 2009
  • 6 Answers
SOURCE: my KX-TG2340JXS model cordless phone not link to base unit .
Password for Dial Unlock is 726276642 (letters PANASONIC).
Posted on Aug 22, 2009
SOURCE: Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Posted on Sep 10, 2009
Testimonial: "This responder did nothing but repeat my initial post and yet gets credit for a solution?"
My Panasonic KX-TG5576 5.8 GHz Cordless Phone, I have it charged. The base phone is working fine. But when I try to use the cordless hand phone and try to use it,m it says: No link to the base, move...
Set the phone on the charging cradle and press the ON button while phone is in crade. You may need to use the speakerphone button to do this. Turning the phone on while in the charging cradle will resync your handset with its base. Try it! It should work!
Feb 01, 2011 | Panasonic KX-TG5576 5.8 GHz Cordless Phone
I have a panasonic KX-TG5431and for a cordless i have no link to base and the cordless off. the battery is slow after charging. Thanks
Hi, I have the same problem. My set is Panasonic KX-TG6522C. Please let me know how you fixed this issue (if you already have)
Dec 13, 2010 | Panasonic KX-TG5431 Cordless Phone
Panasonic KX-TG5631 that works but no display
This problem can have many solutions as it can have many origins. But one of them, and it seems the problem is synchronized, happening to several handsets within a short period of time, as if they ran out of their useful life all together, is caused by the breakage of the flat cable connecting the display to the main board. The thin film conducting material deposited on the plastic base wears off or breaks just close to the display driver making it impossible for the video signals to reach the LCD.
A solution I found was to file part of the white plastic display support base to give the flat cable some slack, and them to insert a rubber wedge between the support and the main board to keep some pressure on the cable, lifting it up a bit, bending the cable as to make the film cracks close and remake electrical contact.
It is not a permanent fix (replacing the display would be) but the phones can go back to normal operation for some time. How long? I don't know yet.
Dec 18, 2009 | Panasonic KX-TG5631 Cordless Phone
All three of my Panasonic KX-TGA630S phones are extremely crackly and full of static. What do I do about this?
I already had the base unit and 2 additional handsets, but one month ago, two of the handset do not charge the battery,
I leave the phones charging for 24 hours, and certainly not reached using 5 minutes and dies
I place it in the base load, and loading sign appears, showing up not being charged as well because if I leave it 24 hours Supposed to be loaded.
Jul 02, 2009 | Panasonic KX-TGA630S Cordless Expansion...
Panasonic KX-TG6051M 5.8 GHz -Caller ID view problem
I have a panasonic KX-TG6051CM 5.8 phone with 3 handsets. After less than a year 2 of the 3 handsets developed the same problem, almost in the same time ( a couples of hours apart). The battery indicator shows low battery and is charging continuously even though the battery is fully charged ( when i swap the battery with my 3rd handset, the battery indicator shows fully charged and works fine ). The handsets were never dropped, never used in a moisture ladden environment ( like bathroom ) and when not in use they were kept in the charger. Any help or suggestions will be much appreciated.
Mar 23, 2008 | Panasonic KX-TG6051M Cordless Phone
Lands Phones Logo
77 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
