E20 for super general washing machine plz help
robotek
  • 1512 Answers
SOURCE: WASHING MACHINE FRONT LOADER
HI there, doing some research for you now....
Posted on Mar 10, 2008
SOURCE: washing machine fault
clogged drain hose
Posted on Mar 24, 2008
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
  • 464 Answers
SOURCE: my washing machine is not spinning and my clothes
You need to get someone to check the speed control board on your machine.
Posted on Dec 09, 2009
beltronic205
  • 1474 Answers
SOURCE: e20 aeg washing machine
Sounds like water leak under machine, Polystyrene Float switch activated keeping pump on thus avoiding flood.
Posted on Nov 26, 2013
Error 2 super general washing machine
I have super general washing machine model is sgw 620 this machine coming error E5
Oct 04, 2016 | General Washing Machines
My machine comes up E20 towards end of program what does this mean
Really need the make and model of your machine as different manufacturers use the same code to mean diferent things. Hotpoint/Indesit/Creda generally use E20 to mean there is a problem with temperature sensing (Which generally indicated that the water heater element has failed. Zanissu/AEG Lavmat use E20 to indicate that the empty pump is blocked (Usually behind a kick plate at the bottom of the machine or a flip open door, you will find a cover that looks a little like a fuel cap). AEG also use E20 to indicate a door lock fault on some models. Personally, the fact that it is near the end of the cycle would indicate to me you have a blocked empty pump
Sep 26, 2015 | Washing Machines
How to used super general sgw 5800
I do not know how to use Super General washing machine SGW 5800 I recently moved to a furnished apartment in Dubai I found this washing machine i could used it 1 time after many trails and after that i tried to operate it again but no hope. ...please help me
Jun 23, 2014 | Washing Machines
My machine had been giving E20 error code - cleaned out filter and pressed start button and it started again ok. During wash it jammed and all lights went on (except spin speeds) and it wouldn't...
E20 is a general error code to get to the real problem try this.. Reading ErrorCodes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold
Oct 11, 2011 | Zanussi ZWD1470W Front Load Washer / Dryer
Washer won't finish wash cycle
e20 on a lot of machines will generally indicate a water emptying problem. Possible solutions: kink in the outflow pipe, internal blockage which is letting the water away too slowly, pump not functioning each of these needs to be checked.
May 24, 2010 | Frigidaire GLTF2940ES Front Load Washer
E20 flashing mid cycle
Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. let me know what code come up... hope it helps
Jul 01, 2009 | Zanussi ZWF1430W Front Load Washer
Atf7000ep code e20
Jun 28, 2009 | Frigidaire ATF6000ES Front Load Washer
E20 code. Not draining
Jun 06, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
No spin E20 alert on washer how can i fix?
E20 is saying that the water is not draining, locate and clean filter if washer has one, check pump and outlet hose for possible blockage, make sure drain hose is not trapped or restricted in any way.
Plz rate my solution.
Thanks.
Jan 21, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
