Question about Miscellaneous
Barry rode his bike for 3 5/8 miles on Wednesday. On Thursday, he biked 3 9/10 times as far as on Wednesday. How many miles did Barry bike on Thursday?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Miscellaneous Master
  • 102,366 Answers
14 11/80
If this is homework, be sure to show your work.
Posted on Dec 01, 2016
My suzuki 2005 s83 boulevard oil looks like chocolate milk.Bike has only 8000 miles.Rode and checked oil the other day was fine.I only rode 1 mile, not that hard.Checked oil today...looks bad
Sounds like water / oil emulsification. Is your bike water cooled or air cooled? If it's water cooled then you may have a gasket leak. If it's air cooled then you may not be riding the bike enough to get a good temp up inside the engine which would drive off the condensation inside the crank case / sump thereby leading to the emulsification. You say you rode an easy mile - certainly that's not enough to get the temp up enough to drive off the water. Was the bike running ok? Was it accelerating and braking ok? If so then try a cautious longer run and keep an eye on your levels. If in doubt consult a bike shop.
Jul 13, 2014 | Motorcycles
Intermittent loss of electrics on st1300 pan european abs model 2005
Hi, Andy and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary your battery may have a cursory reading of 12.5 volts or more but has little or zero amperage and needs to be replaced AGM types more so than lead acid batteries.
2. Faulty alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Faulty main circuit breaker or ignition switch, check for loose connections and continuity.
5. Faulty system and or ignition relay, check for continuity.
6. Faulty ignition coil, ignition/electronic module.
7. Faulty CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Faulty neutral, side stand or clutch lever safety switch.
10. Fuel tank empty
11. Fuel tank contaminated with ethanol sludge.
12. Water or dirt in the fuel system, or clogged filter.
13. Restricted, blocked or kinked fuel line.
14. Faulty fuel pump.
15. Faulty pressure regulator.
16. Faulty or clogged fuel injectors.
17. Lean angle switch is faulty or needs adjustment.
For more information about your issue and valuable "FREE" downloads that you need please click on the blue links below. Good luck and have a wonderful day.
04 VLX VT600CD Engine shutdown while riding
Thread ST1300 Stalling Issue
Honda 2003 ST1300 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 2008 ST1300 Owner Manual
May 30, 2017 | 2009 Honda ST1300 ABS Pan European
Rode home new 883;, next morning bike wouldnt start, battery weak. would not turn engine over. bike is 2009 with 40 miles, bought from dealer
how old is your battery? if it is 2 to 3 years old it may need to be
replaced . charge it up and see if it keeps charge, crank your bike
run it for a short time 4 or 5 min. shut it , and try to start it. if it
drags when cranking go buy new battery.
Nov 01, 2010 | 2006 Harley Davidson XL 883L Sportster
When i bought the bike it was running ok the kid told me i have to change the oil and get a tune up.i rode the bike a rew times and it seemed fine, now when i ride it it has no power at all!! when i give...
sounds like he was right! it needs a tune up!...change plugs and wires replace old air filter and FUEL filter,... put in fresh gas along with some Sea foam from Autzone pour in 1/3 can to two gallons fuel and then push start the bike if you have to and get on it and ride ...it might take about 10-15 miles before you'll notice a difference.
May 13, 2010 | 2004 Suzuki GSX-R 1000 Mladin Replica
Bike sputters with no throtle when trying to start. If any throtle or choke is used bike will not sputter at all. If starting fluid is used bike will start. I've changed plugs ,new gas and cleaned air...
Hi
Check/replace inline fuel filter. Put a fuel injector/carb cleaner fluid in the tank and run it through, this will clean any build up that may be in carbs/injectors.
If problem is still persisting then you'll need to get carbs/injectors removed for cleaning and resetting. Hope this helps, let me know how you get on.
Jason
Apr 03, 2010 | 1995 kawasaki ZX-6R Ninja
Bike won't start
try a push start. if it starts go to autozone an purchase a can of Seafoam $10 pour 1/3 can into two gallons off gas an get on it right away get some high speeds in once in awhile..it night take about 10 miles before you will see a difference.
Oct 05, 2009 | 1999 Yamaha FZX 250 Zeal
Miles
As long as you keep taking care of it the bike will last a long time . 10 thousand miles in 11 months is a lot of miles .Do you realize you rode more miles in 11 months than most people do in a decade
Nov 10, 2008 | 2006 Yamaha V Star Silverado
Electrical Problem 2002 Harley Davidson Roadking police mdl
Your gonna need a voltmeter and a multimeter to trouble shoot this. Invest in a service manual. They have extensive troubleshooting guide
Jul 17, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Miscellaneous Logo
23 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
