Question about Behringer Music
How can I reduce white noise / hissing I'm getting over the mic on a Behringer Xenyx 1204 USB setup?
I have a just bought a Behringer Xenyx 1204USB mixer, a couple of Behringer C-1 mics, and 3m Stag XLR cables. I'm plan to use this set up to record a podcast. However I'm having and issue with what sounds like white noise or a hissing sound on the mics. Are there any suggestions on how to get rid of it? There doesn't seem to be similar noise on the mixer from the USB input, and I can reduce it if I turn the COMP or High/MID EQs down or keep it at a very low gain, but I don't think that's fixing the issue. Please help!
  • 35 Answers
Hi, you didn't say if the mic actually passes sound? The C-1 is a condenser Mic & needs phantom power - switch on the rear of your mixer. If that's no help, what happens if you disconnect the mic, then turn the levels back up? Still hissing or gone? If it's gone then it's the Mic - must use a 3 wire cable, preferably XLR so it gets the phantom power. If the hiss is still there without the Mic then sounds like the mixer is faulty - try some of the other channels..... How loau is the hiss - just in the background or as load as a vocal "one, two" test? A few things to check anyway...... Good Luck!
Posted on Jan 23, 2017
  • 5603 Answers
SOURCE: i have a behringer xenyx
Yep ! First thing is to eliminate any processing resource "hogs" that **** respources and can cause buffer overruns. Eliminate Antivirus, antispyware, and network communication and wireless network programs running in the background while recording.
Next make sure that ALL equipment is powered from the same receptacle or power source. In your case that should be the mixer and the PC.
Next remember that the condenser mic picks up everything... I have 5 of those mics and seemingly noise free environments turn out to have little things that generate fast rising pulses that you don't notice till they are recorded.
Lastly, the air here is very dry and plain old static electricity is rampart... Lady shuffling her feet was sending pulses through the mic cable at our church. They are NOT audible until they get into the sound system as clicks.
I have found that trying to record directely to a USB stick often has ooverruns and clicks... also burning a CD from stick to the CD results in noise due to buffer underuns. Burn from Hard drive to CD and make sure all the other hog programs are shut off.
Posted on Jan 04, 2011
  • 5603 Answers
SOURCE: I record a podcast with
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Posted on Feb 08, 2011
  • 5603 Answers
SOURCE: pls, i will like to
The mic will give very good sound assuming you put it in a studio environment and have no speakers being driven by it that the mic can "hear" or it will feedback instantly.
Your studio should have proper sound deadening on the walls ceiling and floor. There is a lot of information on the web about setting up a studio. Search for it with google. The more studio-like the environment, the more like pro sound you will get. You will NOT get pro-sound in a bare garage or a room in a house without handling the sound reflections in the room. These mics hear EVERYTHING... they are a high quality mic.
Posted on Feb 25, 2011
technical114
  • 1851 Answers
SOURCE: I have the Behringer Xenyx
Is the sound a low frequency buzz or high frequency hiss? With all the input level controls at the minimum position and the output level controls at the maximum is the sound audible?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Mar 31, 2011
  • 5603 Answers
SOURCE: have a Behringer 1202 Xenyx
You are running your balanced cable into a windows 7 PC? What interface are you using... not the line input on the PC I hope as it is NOT balanced... it is Stereo input with UNBALANCED input. If you tie the mixer using a balanced to 1/8 inch balanced connector you will get plenty of hiss since you are driving the stereo channels oppositely. For high quality, get a good audio interface that runs on the USB of the PC. If you can tolerate a bit of noise but wire it correctly, then you will need to use two UNBALANCED lines out of the mixer for L and R and merge them to a stereo 1/8 inch plug for the PC.
Posted on Jul 11, 2011
Where do you connect a midi controller on a Behringer Xenyx 1204usb mixer?
You can connect where it is possible. I hope you will understand.
Aug 04, 2016 | Behringer Music
I need driver update to connect with pre sonus artist one software
If you use the Behringer ASIO drivers (available from their web site) it will connect just fine, you should also be able to use the sound card drivers that came with the computer as they should pick up on the mixer (assuming it is a USB version) but you do not say if you have a Mac, PC or what operating system you are running so it is impossible to be precise
Mar 15, 2016 | Behringer XENyX 1204 XENyX 1204 12 Channel...
What causes my cd/tape input doesn't work anymore.
Make sure that the cable going to the left and right inputs is OK. Try another cable or test with a different recorder.
Oct 01, 2014 | Behringer XENyX 1204 XENyX 1204 12 Channel...
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
Mar 02, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
Have a Behringer 1202 Xenyx FX, balanced cable into a new windows 7 PC and keep getting hiss. When I raise the gain, mic or master volume the hiss is more awful. my internet broadcasts sound awful. what am...
Jul 10, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
I have the Behringer Xenyx 502 mixer, it's brand-new, and for some reason there's a weird buzzing/hissing sound in the main mix that will just not go away no matter what I do. I've unplugged everything,...
Thanks and regards
Stelios
Mar 31, 2011 | Behringer Xenyx 502 Audio Live Music Mixer...
Pls, i will like to know how i can get a pro sound with my beringer b2pro mic with my xenyx 1204usb mixer. i mean mic settings
Feb 25, 2011 | Behringer B2PRO Gold-Sputtered Large...
I have a behringer xenyx 1204usb mixer with a mxl 990 mic and i have problems with static. thats all i have hooked to the mixer so i dont think its a conflict. i have tried recording in audition, pro...
Jan 04, 2011 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Type pf op amp in a Behringer XENYX 1204USB Mixer and a Mackie - 1202-VLZ3
Behringer uses 4580's in appropriate packaging everywhere. There are 339 comparators for the level indicator area.
The Mackies uses both NJM2068 and NJM4560M
The 2068' are used in most of the low noise areas and the 4560 is used in the 75Hz high pass filter for example.
Jul 22, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Music Logo
122 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
