Question about Makita Saws
How do i remove the inner flange on my Makita 2401b 10" Miter saw. It appears that it should come strait off but mine won't budge.
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
SOURCE: Makita LS1013FL manual missing
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/LS1013 then download manual
Posted on Sep 11, 2009
VtToolMan
  • 704 Answers
SOURCE: Unable to lift the saw blade Makita Miter Saw
Look at the pivot point on the rear of the miter saw for the push/pull locking pin. The pin is there so you can lock the saw in the down position for easier carrying. To unlock the saw, simply pull the locking pin out (Makita calls this the "stopper pin"). Then you can use the saw and easily raise and lower it for cutting.
As you might find it helpful to have, I have included a link from the Makita web site for a free copy of the owners manual that you can print or save for future use and reference. It has some handy info on use and care of your saw.
http://makita.com/en-us/Assets/images/Products/LS1030N/owners_manuals/LS1030N.pdf
Hope you find this Very Helpful and best regards!
Posted on Sep 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: how do I install the spring after changing the
what spring? do you mean the one in the guard? if so you don;t have to remove it to change the blade, give me the exact model number or you can go to makitatools.com and download a breakdown that shows the reassembly of the guard, it is not that hard, and also you can download an owners manual that shows the proper blade replacement procedure.
Posted on Jan 19, 2010
SOURCE: makita LS1013 compound saw wont slide,instruction
You may find, you have a lock, button, that needs to be held in, before you can drop the saw to cut.
Posted on Apr 28, 2010
Can I bypass (hotwire) the controller on my Makita ls1013 Miter saw?
Not a good idea. Miter saw are too dangerous to be altering them in any way.
Aug 24, 2014 | Makita 10" Dual Slide Compound Miter Saw...
Makita 2401b
Some mitre saws have extra windings in the field coil so a possibility is a break in this brake coil another possibility is the switch some have a contact that switches the back emf from the field coil to the brake coil when you release the trigger. And believe or it or not some times changing the brushes affects the braking have seen this a few times on the LS1013.
Mar 15, 2014 | Saws
I have the blade bolt off of my ryobi miter saw but the blade wont come off of the spindle
tap the blade on the back side to loosen it off. The wood sap has probably dried out and is acting like a glue on the back flange washer.
Feb 13, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
I can not remove armature caseing from makita miter saw
The casing at the saw end will have an inside case that is bolted either from behind the gears or from the armature side by screws. This has to be undone to allow the bearing to separate from the case
Jan 16, 2013 | Makita 10" Compound Miter Saw LS1040
How do I replace the blade guard on my 10" Makita
If you want to replace the plastic cover there is a screw towards the front of the saw that must be removed and then the bolt at the back loosened and the guard will pull off. If you need more info get back to me with the other questions and I will try and help
Jul 10, 2011 | Makita 10" Miter Saw LS1030N
How do I get the base off I've taken the fence off and the screw in the center out.
Hi
Not sure if you want to remove the center base. If yes with the center bolt removed it should go.
If this can help view the parts diagram.
http://www.ereplacementparts.com/makita-ls1030n-miter-saw-parts-c-97_98_99_321.html
Feb 07, 2011 | Makita 10" Miter Saw LS1030N
When I shut the saw off after cutting the blade keeps turning for quite a while and does not shut off like it used to.
could be a couple problems, loose blade flanges, dirt in the brush area or just worn brushes. I would take a look at the brushes first. UNPLUG tool before removing brush caps. Let me know if I can be or more assistance
Oct 18, 2010 | Makita 10" Dual Bevel Sliding Compound...
Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Jul 06, 2009 | Makita 10" Dual Bevel Sliding Compound...
Replacing the blade on a Makita 255mm miter saw
I take it you have both flanges and the washer that is behind the innner flange, if not stop there and you need to get them. As far as the blade goes it depends on what size arbor it has. You would need to use the washer that goes on the spindle with no play (movement) and put the blade on the washer I would not use a washer that is thicker than the blade. Put the outer flange on making sure of the direction and then the blade bolt LH thread. Let me know if you have any problems before starting the saw PLEASE and I will help more.
Feb 17, 2009 | Makita 10" Miter Saw LS1030N
Saws Logo
149 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
