Question about Refrigerators
Red alarm light on Defy F640 keeps on flickering and the fridge is not cooling as it used too.
    New Friend:
    Problem Solver:
  • 9 Answers
U are just in need of frion that's it
Posted on Jan 22, 2018
  • 552 Answers
Possible defrost issue. May be caused by non-sealing doors, broken defrost heaters, bad thermistor, bad control board.
Posted on Dec 09, 2016
Hi i have a defy f640 SS fridge...the freezer side works fine...but the fridge side is not cold as before...please help
It could be that your evaporator fan motor has broken ... which for some refrigerators results in your symptoms of good freezer temperature and too warm in the fridge side. I am not familiar with your model so there could be other issues.
Jan 11, 2018 | Refrigerators
How do i replace the bulb on my Defy double door fridge F640?
In my opinion, it is very risky job. It may damage your fridge itself if you are not properly aware of that. I prefer a refrigerator mechanic to do this job.
Aug 04, 2016 | Cell Phones
DEFY F640 Fridge/Freezer side by side. The freezer made clicking sound, and green light flicker for a while then stops. Now it is not freezing anymore.
It could be the theromstat, clicksen or the compressor.
But I think its the clicksen it is faulty and can't handle the amp stress test I hope for your sake other wise I believe its the compressor.
May 26, 2016 | Refrigerators
Frigidaire elite, red alarm light on,freezer defrosted, fridge icing up
Sounds like your heater is either out or the connectors are loose causing it not to be able to cool properly from ice build up
May 08, 2014 | Frigidaire Refrigerators
Defy f640 wiring diagram
Defy F640 freezer fan keeps switching on and off and does not cool.
Jan 19, 2014 | Freezers
My double door firge frezeer is not icing and the red alarm button is alarming all the time
you mite need to replace your thermostat,...... the alarm button is
telling u that your fridge is not cold enough, there is also probably another prob but u need to b a electrician to sort it on the top of fridge there is a panel,.. under that there is a fusible link if one blows it will need to b replaced its soldered in no job for u unless ur a electrician hope this helps
Oct 24, 2013 | Red Defy Helmet Youth 2012
Defy fridge f640 wiring diagram faulty compressor or thermostat
Hi my name is jp. Got a defy f640 the freezer not working. Trips power. Wires been removed at back of the compressor. Need to know where the wires need to go
Dec 22, 2012 | Refrigerators
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Refrigerators Logo
669 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
