Question about LG Dryers
LG gas dryer baffle need to tighten how do i get to the baffles?
    New Friend:
Kewkewkewkewk, adadadadadadadadaadadadadadadadah
Posted on Dec 01, 2016
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
What is the easiest way to access the dryer baffle to tighten them
Hello Jim;
My name is Peter. I am a retired field service appliance technician.
Dryers do not have baffles. Open the dryer door and locate the model number, then go into the following website and put in your model number to get a diagram of you dryer parts. Water Filters Lawn Garden Appliance Parts
Jan 30, 2016 | Whirlpool LTG5243DQ White Thin Twin 24"...
Fix rattly noise in gas dryer
could be coins in the baffles, sometimes coins make it into your dryer, and they slide under the baffles, remove or open the top of your unit and you will see the screws that hold on each baffle, remove the screws and the baffle will come off inside the dryer with whatever is in there. then re-secure the baffles..
Oct 24, 2015 | Kenmore Dryers
Baffle is loose in dryer,how do I tighten it
Gain access from the top. tighten up baffle with 1/4 nutdriver i believe.
Feb 07, 2011 | Dryers
Short baffle is loose
You can pop the top with a drywall putty knife there is two tabs on each side. This will allow you to access the drum. Then tighten the screws holding the baffle in place.
Jan 22, 2010 | Maytag Dryers
One of the finns inside the dryer is loose, how do I tighten it?
To tighten the drum baffles, all you have to do is UNPLUG the dryer and lift the top panel. The bolts that hold the baffles in place are located on the outside perimeter of the drum. There's usually a minimum of two per baffle. If you cannot figure out how to lift the top panel, post back with your complete model number (located on a nameplate around the door opening or back of the operator console) so that I may be able to assist you further. I hope this helps you.
Oct 28, 2009 | Dryers
Baffle is loose on drum. How do we get access to fix the baffle
The screws that hold the drum baffles in place are located along the outside of the drum. Usually, you need to lift the dryer top in order to access them, and they can be tightened without removing any components. However, all dryers are not contructed the same and access to the drum can vary. If you would please post a brand name and model number it would help in being able to determine exactly how your dryer is configured.
Aug 31, 2009 | Dryers
HOW DO I TIGHTENED UP A LOOSE BAFFLE IN MY GAS DRYER
if you have the model with the lint filter on top,remove the 2 lint filter screws,pull the top toward you and up and your in-mike
Jun 01, 2009 | Kenmore Dryers
Dryers Logo
56 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
