Question about Hyundai ImageQuest HQP421HR 42 in. HDTV-Ready Plasma Television
Problem with a Hyundai HQP421 HR Plasma TV
Powers up, image & sound are ok, but after 1 minute or so (this summer it was around 20 seconds), it shuts down suddently. I have to wait around 5mn to make tv power up again. Opening the back panel does not show anything suspect, except 2 big 400V capacitors on the main power board that are slightly bulged, but not leaking. Any idea welcome.
  • 246 Answers
Ur board is fried or almost fried. the price to fix is a lot more than to buy new
Posted on Dec 01, 2016
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
Aug 23, 2013 - Uploaded by
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
Sep 26, 2014 - Uploaded by
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Panasonic TC-P50VT20 blank screen with vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Apr 05, 2017 | Panasonic Televison & Video
Hi everybody, I have a Philips plasma 50PF7321. Two main issues. Sometimes I only get half the screen on ( bottom half). In this case I get a "cut" image and not a "compressed" image, I...
It sounds like you have a problem were the Y sus/buffers board (the one on the left ) has issues with the connectors to the screen need unpluging cleaning and putting back
Apr 11, 2017 | Philips 50PFP5332D 50 in. Plasma...
The audio component of our TV is no longer
Better get assistance from the authorized service center. Before that, check whether you have pressed the mute switch!
Apr 22, 2010 | Hyundai ImageQuest HQP421SR 42 in....
Tv shutting off then comes on
your lamp is going out, they last around 2 years, on the average, this is easily replaced by you, door is on the right side of the tv, you can take the lamp out, if it has a bubble on it, it is getting ready to go out
Jan 09, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Powers off after 15 seconds to 1 minute
solder issue at the flyback. try resoldering the flyback
May 17, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
Sony KV 20S40 20" tv flutters, reduces in size and then shuts off
The set most probably has cracked solder joints in one of the deflection circuits, which is pretty common. The picture tube and major components are fine. A good tech can quickly resolder the main board and that should not cost too much. If your set came into my shop I would charge about $50 but ask around, the shops in your area will vary.
Jul 31, 2007 | Sony KV-20S40 20" TV
Open Questions:
Hyundai 32" LCD displaying "invalid service "on some HD Staions Have just purchased a Hyundai 32" LCD Model CB-L3236LCD. Locallly I have Channel Prime HD and then Prime1, Prime2 and Prime3 which may or may not have differing programs to Prime HD ( I imagine in the future they will). Problem is on Prime 1,2,3 I either get a flash of the program then it returns to a blank screen with a blue box jumping all over the screen with "Invalid Service" written inside the box. Occassionally I may get a great reception on these stations but the Invalid Service box still appears. I can have a reception on Prime 1 say ( with Invalid Box0 and a blank screen on 2 and 3 with the invalid box. Very random it appears but common thread is the "Invalid Box". I only experience this with the Prime 1,2,3 Stations. I have a an older masthead amplifier booster system and I am about 5 kilometers line of sight from the Prime translator . I have a Panasonic 52" LCD as my main set which experiences no problems and have tried the Hyundai 32" on the aerial outlet which supplies the Panasonic in event the problem was due to a weaker signal at the Hyundai's normal location BUT I still have the Invalid Service problem with Prime 1,2,3. I went back to the store of purchase and tried their display set ( running on 'rabbit ears' aerial and less than one kilometre from the translator and the same problem existed on that set with Prie 1,2,3 only Anyone have any solution to this problem. Any software upgrades available for these models? Thanks in advance for any replies
Dec 19, 2008 | Hyundai ImageQuest HQP421HR 42 in....
Hyundai ImageQuest HQP421HR 42 in. HDTV-Ready Plasma Television Logo
179 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
