Question about Dryers
Simplicity freedom sucked a table cloth into motor cooling vents. Shut it down. Removed cloth, but it does not run. Any ideas?
  • Dryers Master
  • 5,323 Answers
CHECK FUSE
Posted on Dec 08, 2016
5 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Kenmore Gas Dryer Gets Hot, Shuts Off Early in Cycle
Sounds like a faulty high limit or cycling thermostat. The thermostat tells the dryer to heat until the interior of the dryer reaches a certain temp. It should be mounted on the exhause duct inside the back of the dryer. It should look something like the one in the picture:
Hope this helped and best wishes.
Posted on Jul 27, 2009
ftw1952
  • 10319 Answers
SOURCE: Whirlpool dryer LEQ9858LW0 won't cool down -
heat sensor is at fault
replace it before it starts a fire
Posted on Jan 30, 2010
TheMobilian
  • 8220 Answers
SOURCE: a piece of clothing got
LG dryer disasembly notes:
To disassemble remove the top first by removing screws in rear. To take off the control remove to screw on each side of the back. All connectors are color coded. Cannot screw up reassemble.Lift control out and up. Control board has 4 screws and is replaced as a unit. Keep the selector knob.
Removing and reversing the door
Remove the screws from opposite side and then remove the latch pull out the latch no wires are there. Take the door off and reverse it then replace the latch and shorter screws for extra holes.
Remove the front:
Disconnect the dryer light and door switch wires. Move harness out yer way. Remove 2 screws at the base of the door opening and 4 screws along the top. Tip the panel to the front and lifts off. Next remove the top bracket 2 screws each end. Lift brace up and off.
To remove the shroud/panel 4 screws are removed and lifted up and pulled forward. Disconnect the wire to the humidity sensor.
Remove the belt from idler and yank the drum out. (The belt goes under the tensioner then over the pulley then release it and the spring holds everythang in place like a DOT dryer.) The grooved/ribbed surface goes to the tub side.
LG Dryer
Posted on Jan 30, 2011
  • 18 Answers
SOURCE: dryer shuts off before cloths
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Posted on Feb 11, 2011
Simplicity freedom sucked a table cloth into the motor cooling fan. Shut it down
if there is no power at all and its not turning on check fuse in plug and make sure it has now blown.
Dec 01, 2016 | Cars & Trucks
Simplicity regency 12 hydro sucking oil into carburetor. what could be the problem?
blown head gasket... it pressurizes the engine causing oil to blow out...
or
oil is WAY to full
should of mentioned the engine brand because simplicity doesn't make it !!!
Oct 18, 2014 | Simplicity 2691011 - Regent 42" 21HP Lawn...
Dryer runs for about 5 minutes then shuts off the clothes are hot
Your vent may be obstructed causing the dryer to trip, once it cools down it will reset itself. The way to see if thats the problem is to disconnect the vent and run the machine, if it doesn't shut off, you will need to clear the vent.
May 13, 2011 | Kenmore Elite HE4 Electric Dryer
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Feb 11, 2011 | Dryers
The dryer will not shut off automatically. It would run forever if I let it. It also takes a very long time to dry the clothes. As if it's not heating them properly.
Well first of all you may try running the dryer with the vent hose removed. A slow vent will cause what you're describing. Then you'll need to look at the cycling thermostat. That is the part that tells the timer to advance. It sends a signal to the timer when the proper temp is achieved in the drum. Means when the element cycles off the timer motor moves a little bit. When it cools down and the element comes back on the timer stops. This action takes place when you're using one of the auto cycles.
If you have a slow vent it can cause the high limit thermostat to do the cycling. Please let us know for further help or information.....
Good Luck!!
Thanks for using FixYa!!
Jan 26, 2011 | Hotpoint NLLR113EV Dryer
Gas dryer turns off when load is nit dry
You may want to clean out the dryer's insides as well as your venting that leads outside. This may be the reason your dryer isn't fully drying. It basically isn't running efficiently enough due to age or lint build up or both. As far as the running after it's cooled down it may be a "wrinkle guard" where it tumbles the clothes until they have cooled down.
Mar 14, 2010 | Dryers
Hi. I purchased a Simplicity Freedom about 2 years ago. I have had it in for various repairs several times. One persistant problem that the repairman cannot seem to fix is the dirt does not fall down into...
You can let the vacuum run alittle longer so the bag fills up with air, also make sure that the bag in on correctly and you have the right bag for the unit. Let me know if this helps.
Oct 12, 2009 | Simplicity Vacuums
Simplicity freedom model f3300 makes loud noise when running.
sounds like the fan might be broken in the motor
Oct 02, 2009 | Vacuums
Dryer will start to dry clothes then shut off
sounds like the over-temperature thermostat is the source of problem. This device prevents over heating by removing power to heating coil when normal thermostat control has failed. Perhaps your model takes it a step farther and removes all power to machine for safety. But this device is "tripping" too early unless you can find that your normal thermostat has failed. One test for this condition is to remove power to heating coil (ONLY) and retry a cycle. If your symptom disappears, then the over-temperature thermostat is faulty. If no change, there is either a faulty controller circuit or an intermittent short that is rising temperature-sensitive.
Dec 05, 2007 | Whirlpool LER5636P Electric Dryer
Dryers Logo
137 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
