Question about Samsung Refrigerators
I can't locate the defrost sensor on Samsung side by side
    Top Expert:
  • Samsung Master
  • 77,932 Answers
It is located behind the panel under the doors in most models, it is not a sensor it is a timer/relay
Posted on Dec 01, 2016
What part Samsung RS2530BWP uses, Sensor or Bar
either the heating element used to defrost is bad
or there is usualty a small inline thermal fuse
replace it
test the elements resistance is aok
look on ebay for a new inline fuse and also element save the grief of testing
Dec 08, 2014 | Samsung RS2530BWP (25 cu ft) Side by Side...
What does it mean when my samsung side by side refrigerator displays 5 E
5E Means Fridge Defrost Sensor Error.
You will probably have to call an Engineer because this does not necessarily mean the defrost sensor is faulty and you would need to check that the evaporator and drain heaters are working, the thermal fuse for the heaters is ok and if they are fine, the sensor resistance should be checked.
Jul 09, 2014 | Samsung RS265TDRS Side by Side...
How to change Defrost Temperature Sensor Samsung DA32-00006W
We have here a video link that can help replace the defrost thermostat
Nov 29, 2011 | Samsung RS2630SH Side by Side Refrigerator
Freezer not auto-defrosting; replaced defrosting coils. What controls them?
Hi welcome to fix-ya. The defrost is started when white sensor located top of coil left side. That tell the motherboard to defrost. When done the same sensor shuts down defrost. The defrost termintor that is wired in line with heater is only for safety. I hope this helps.
Sep 18, 2011 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
I have a samsung side by side srs537nw. both side are not working properly. the fridge wont cool and the freezer turn into a fridge.
Had exactly the same problem. Found the cooling coils are not defrosting, everything was iced up inside the back panels. The drain was blocked, water pooling underneath also.
Remove all the plastic panels in the back of the freezer, including the temp. sensor (unplug) and fan (unplug). Defrost everything with a hair drier.
Make sure that the drain at the bottom is free, a small plastic tube which takes water down into a pan where it is evaporated by the compressor etc.
Replace the defrost sensor - the most likely faulty part. This costs about $Au 20.00 from Samsung (just ask for a defrost sensor for the model of fridge). This sensor fits in a plastic cage attached to the top of the cooling coils, has wires which plug into a socket. Reassemble the fridge and see if this has solved the problem.
If the fridge still does not defrost automatically, you may need to replace the circuit board ($Au 80.00 from Samsung). This board is found from the back of the fridge, in a plastic box behind a back panel at the bottom of the back of the fridge. Lots of wires to unplug!
There may be other problems, like a faulty thermostat on the valve which controls circulation of cold air into the fridge from the freezer, I have no experience of solving this.
Samsung mechanics are HOPELESS in my experience, replacing the two parts above will be less expensive than a call to them. Good luck!
Feb 10, 2011 | Samsung RS2534 Side by Side Refrigerator
Freezer and fridge don't cool at all. everything else works fine
There is a fault with samsung fridges that when it goes on defrost it will not start the compressor or the fans again. If you turn on the power the fridge should run for a couple of hours and then stop if so you will need to get a tech out to order a samsung yellow sensor and a fridge defrost isolation sensor. If the fridge does not work at all if you would like i will talk you a couple of little checks before calling someone out.
Hope this helps
Jan 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
Freezer won't stay defrosted
defrost heater is behind the freezer rear panel along with the defrost sensor,check doors are sealing correctly, usual fault on this unit isdefrost sensor
Sep 02, 2007 | Jenn-Air JCD2389G Side by Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
