Question about Cell Phones
My super general giving E 20 and not taking any order ,what should I do plz ?
Super general air conditioner error code is E0
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset. If you need anything else air conditioning related don't be afraid to check us out our AC Repair and information online
Sep 14, 2016 | Heating & Cooling
Restore factory settings
it would be best to post the cell phone model as each one usually has different steps to be followed in order to restore factory settings. Generally the restore factory settings option is located under "general settings" or under "memory settings" give or take.
Oct 18, 2013 | Cell Phones
HAVING PROBLEM WITH COMPRESSER TO HOT
If the condesnser coils are clean and condenser fan blde as well and refrigerants not low or(non condensibles) air in the system (high head pressure) than the superheat to the compressor should be ok, not more than 20 deg super heat at the compressor generally, if thats not it the thermal overloads bad or compressors low on oil or tired, take amp deaw and see pressures to know for sure, check super heat and subcooling too.
Jan 12, 2011 | Beverage-Air 23.1 cu. ft. / 654 liter...
Sir, I had purchase Hero Honda Super splendor bike on year 2006. That time dealer said to me this bike give u 65-70 km millage per liter. But after 4 year this bike cannot give even 55+ millage per...
There are many factors in fuel economy when it comes to a small motorcycle. The biggest is riding style or habits followed closely by weight. Be this weight a single rider with gear, two riders with gear and high speed. If your motorcycle is in proper mechanical order it should produce close to what the dealer said. Test conditions and real life conditions are much different. If you test your motorcycle with you alone on it keeping the speed below 70kph and have the proper tire pressure operate the motorcycle conservatively you will see a huge increase in your KPL. Check your owners manual for the correct tire pressure and adjust your tire pressure accordingly. I suspect you are operating with lower pressure then what is specified. These are great looking small bikes with exceptional fuel economy treat it right and it will reward you, ride it hard and it'll cost you.
Dec 14, 2010 | 2006 Hero Honda Super Splendor
MY WASHING MACHINE AGITATOR WON'T SPIN. I CAN HEAR THE MOTOR RUNNING THOUGH.IT IS A GE SUPER CAPACITY WASHER. MODEL NUMBER WHDSR209.
then your motor coupling has broken cost for part is about $20 can buy from your local appliance shop or order from REPAIRCLINIC.com
Jan 09, 2010 | General Electric WHDSR209DWW Top Load...
Box super no channels
Pure ntl codes. 5401
00 A9 5D 4E FE 20 E1 2D 03
01 88 6B 69 7E 94 B6 BB 1E
Press menu on remote, On installation press 1570,On nagrivision press O K, This will take you to the providers,scroll right to yours and using the remote put codes making sure to press store after each set, exit menu after that. you should have all channels then.
Dec 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
Loading error
if you are talking about the game that is dusty or dirty (fingerprints etc..) just give it a gentle clean with a little white spirit on a soft cotton cloth, then dry it off gently using a soft cotton cloth.
If you are not talking about the game please give more information
Jan 17, 2009 | Nintendo Wii Console
The gas pedal is all the way down to the floor and is idle high and it dont go over 20 mph
Your transmission is most likely toast, take it to a tranny shop to diagnose
Jul 29, 2008 | 1996 BMW 318
Hard drive error #0041
This sounds to be a hard drive issue. Run a DST or short test diagnostic, this will give you a pass or fail on the hard drive. The other thing that is concerning is having to take out the battery in order to start. This generally occurs when a battery develops a dead short, but usually it's a well used battery. This is a hardware issue and it will not get any better. If you can, take it back and exchange it, RUN don't WALK because most retailers do not like to exchange electronics and the return period is generally short. I am a firm believer in Dell, they make good machines, and you should not have these issues with this machine, even at 2 years old much less 20 days. Be firm with them and demand an exchange, even if you have to take it to management. Also tell them you spoke with a tech (they don't have to know that it was over the internet) and his advice was exchange because the machine shouldn't have these problem at this point. It's still a baby!!!
Jul 01, 2008 | Dell Inspiron 1501 Notebook
How do i open it?
pull up on the round button on the left..
Jun 27, 2008 | Pentax ME Super 35mm SLR Camera
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
