Descale a clogged espresso machine
Wont pump water through the machinr
    Top Expert:
  • Washing Mach... Master
  • 8,213 Answers
Posted on Dec 01, 2016
Testimonial: "Thanks but it is already clogged....is it officially done for? I love(d) this machine"
My Saeco Xsmall stops before brewing the coffee
1- The grind fineness setting is too fine. Pump is not able to pump through the compacted coffee grounds.
2- The machine is not descaled. The Calcium deposits in the hydraulic system have reduced the pump pressure. The partially clogged water passages can generate a back pressure to reduce pumping pressure. Was the machine descaled in the past two or three moths? If yes, what was the descaling product used?
3- The pump may be air locked and not able to pump water.
4- Oily beans may have been used. Oily beans are poison for the all fully automatic espresso machines. This clogs the grinding chamber or the grinder outlet. This model is made in Romania made in 2006 or after. This machine has a Ceramic Burr grinder 2006 which is a huge problem to clean adjust beans quantity per shot of espresso etc. etc. Occasionally it will dump dry coffee grounds when the quantity of beans powder is insufficient.
Based on the above details, you can figure out what is wrong and fix it. See the exploded parts diagram included, for help. Services Unlimited Inc Parts Guru Since 1988
Dec 29, 2016 | Saeco Coffee Makers & Espresso Machines
Error code 5 on saeco minuto coffee machine
Error code 5 means the water flow is obstructed. Here are possible locations:
1- The machine was not descaled. Calcium deposits are clogging the water system.
2- The flow meter is not passing impulses for water flow speed & quantity.
3- Descale Descale Descale.
Before you select the automatic descaling, make a few espresso without adding coffee grounds. The automatic cycle does not clean the coffee side of the machine. You have to do it intentionally.
Dec 18, 2016 | Saeco Coffee Makers & Espresso Machines
Fault on Siemens TK76K573, after pump replacement
The water passages in the espresso makes may be clogged. Please descale the machine. Depending on the period for which the descaling was not done, it may need nore than one descaling cycle to remove accumulated Calcium deposits.
Calcium deposits narrow water passages and reduce the pump pressure to push water through the coffee grounds.
Oct 18, 2014 | Coffee Makers & Espresso Machines
Steam wont work on my coffee machine
If you've used the machine for awhile, and you have not cleaned/descaled it, it may be clogged with mineral deposits. Citric acid, a white natural mild acid is a good descaler. It comes in powder form and readily dissolves in water. You can locate citric acid on the web (ebay). White vinegar also works, about 1/2 & 1/2 with water. Run the solution through the machine to descale it. It may take a few treatments to get all the mineral deposits out. Use about 2 tbsp of baking soda in water afterwards to neutralize the acid.Hope this Helps!!
May 13, 2014 | Williams-Sonoma Saeco Intelia Espresso...
My ec702 stopped pumping water through. the wand still works. we descaled and cleaned out all filters. nothing. how do we fix it?
I suggest you try cleaning/descaling again. Possibly the scale that was loosened did clog the coffee maker up.
May 12, 2014 | DeLonghi Pump Espresso Machine Stainless...
Lines are clogged and the coffee is not coming
Use Scalekleen or other citric acid.
1-
Always use the right descaling products.
Descaling chemicals purchased from supermarkets may not be suitable for the
machine. Use of Vinegar is prohibited by manufacturers. Please read the
operating manual. Do not use Cafiza, Cleancaf or PuroCaff. These are coffee
cleaners recommended for back flushing coffee machines.
2- Always dissolve the Descaling chemical in a container and pour into the water
tank. Never add directly into the water tank. Crystals of chemical will slide into
the filter & pump and block the water hose and restrict flow of water.
3- Do not pour solution when the tank it is on the machine. In fully automatic
machines, the bean hopper is next to the water tank. The solution / water can
accidentally get into the bean hopper and cause serious damage to the grinder.
4- Espresso machines have separate water passage for Hot water from steam
pipe and espresso dispensing. Flush the solution from both sides, alternatively.
Turn machine on, flush one cup from steam pipe and turn machine off. After a
pause of 3 to 5 minutes turn machine on and make one large espresso (4-oz.).
Repeat this process until all of the solution in the tank is used up.
This method is best both for semi-automatic & fully automatic espresso
machines.
Using Electronic programmed method does only half the job as it flushes
descaling solution only through the steam pipe. The machine must be flushed
with solution from espresso side as well. Automatic descaling method should be
completed by making 6 espresso with or without coffee (using pre-ground cycle
when available).
5- Rinse the water tank and fill with fresh clean water. Repeat the rinsing process
alternatively until four tanks of water is used up to flush the chemical out.
Caution: Do not leave the machine before completing the rinsing
with clean water. The solution left inside will corrode & tarnish
metallic surface.
Do not leave Chrome plated objects submerged in descaling
solution for more than 10 seconds. The chrome will dissolve and
leave the item permanently corroded and black.
Jun 05, 2009 | Saeco VIA Venezia
Espresso does not make
Remove the portafilter and press the brew button, if the water flows from the head with a nice flow then the problem is with the grind (too fine), or the coffee has been Tamp too hard.
If water barely flows when you press the button then try backwashing the machine and removing the shower screen to clean it.
May 19, 2009 | Coffee Makers & Espresso Machines
No water output even after manual prime
Water line is clogged you will have to open machine and find where the line is clogged.
Mar 23, 2009 | Saeco Vienna SuperAutomatica Coffee...
SOLIS MASTER 5000
Try descaling your machine, because it may be clogged. Boilers heat up the water to produce steam. If descaling doesnt work you may have a boiler related problem.
Find descaler on www.CeriniCoffee.com
Nov 26, 2007 | Solis Master 5000 Espresso Machine
Washing Machines Logo
Top Washing Machines Experts
