Question about Hardware & Accessories
How do I program a 111Woods outdoor timer with only one button?
My ge model 15117 heavy duty timer will not go off in the auto mode. I changed it from auto to off to turn my pump on and then went back to auto and now did not turn off when timer expired
I cannot repair defective timers, and there are complaints about this timer's MODE button.
Most people complain they can't get mode to set.
Avoid the MODE button after programming timer.
Reset the timer by pushing CLOCK PROG MODE buttons. Then re-program the timer per instructions, and then press CLOCK button to exit programming and timer is in Auto mode and ready to work.
No need to press MODE after programming timer.
Typically, this timer has limited 1 year warranty.
http://waterheatertimer.org/pdf/GE-15117-Manual.pdf
http://waterheatertimer.org/GE-timers-and-manuals.html#15117
15117 is not heavy duty timer. Both outlets combined are rated 1000 watts incandescent and 1/4 HP. Check nameplate on your pump for HP rating.
For limited-lifetime-warranty timer, rated 1/3 HP, choose Intermatic HB800RCL 2-outlet timer.
Cost twice as much as GE 15117.
For 1HP outdoor pumps choose Intermatic P1121
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Aug 08, 2011 | Sport & Outdoor - Others
We replaced the battery for our Intermatic Rain Tight Outdoor 7 day digital timer MODEL HB71R70 but the instructions to reset the timer have been misplaced. Could you please supply us with step by step...
Hi Maggie.
Intermatic no longer makes HB71 timer, and I cannot find instructions for the timer.
Intermatic website is offline on weekends starting March 2011, but I have searched the site numerous times over past year and they do not post that manual.
However I might be able to piece together steps if you add a comment and include in-focus photo of timer and buttons. Also include anything you can remember about setting the timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
My understanding so far is that this timer has 2 slide buttons, and several push buttons.
Typically slide button timers require both slide buttons to be in one position for setting timer, and another position for programming timer, and another position for operating timer. The complicated steps are why timer has been replaced with newer models with sleeker programming.
If you do not want to bother sending photograph, or working on the problem, then buy another outdoor timer for 20$
http://waterheatertimer.org/Woods-timers-and-manuals.html#6-24
http://www.amazon.com/Woods-59403-Heavy-Duty-Outdoor-Digital/dp/B002KS7EOK
http://www.homedepot.com/Electrical-Dimmers-Switches-Timers/h_d1/N-5yc1vZ1xg8Zbm2d/R-100685861/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Apr 23, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How to set the Nordik TM-065? It was bought for
The Nordik TM-065 timer looks similar to Woods/Noma N1506
http://www.advancedtimer.com/TM-065.html
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
Plug timer into outdoor receptacle.
Press Time button until correct time displays.
Dot on display is for pm hours
Nordik appears to be on the 24 hour clock instead of am-pm
Set operation of timer by pressing Mode button.
P flashes for program mode.
Press time button until starting time displays.
Press Mode again and E flashes.
Press time button until finish time displays
Press Mode button to exit programming.
Dec 17, 2010 | Woods Outdoor Lighting Timer
How do I program a Noma N1506 timer?
All Woods timers and manuals
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
I need instruction for the timer
You posted under Woods 59403 timer
If this is not your timer, add a comment.
59403 timer manual:
http://waterheatertimer.org/pdf/Woods-59403.pdf
If you have different Woods timer, look at images at link below to identify timer.
Add a comment if you need help.
59403 programming Instructions:
Plug timer into indoor or outdoor wall outlet.
Set clock:
Hold down clock button.
Press day button until current day displays.
Press Hour button until current hour displays.
Press min button until current minute shows.
Release clock button
Program timer:
Press PROG button until 1 ON displays
This is Event1 ON
Press Day button until selected day or days displays for event1 ON
Press Hour button until selected hour displays for event1 ON
Press Min button until selected minute displays for event1 ON
Press PROG button until 1 OFF displays
This is Event1 ON
Press Day button until selected day or days displays for event1 OFF
Press Hour button until selected hour displays for event1 OFF
Press Min button until selected minute displays for event1 OFF
Press PROG button until 2 ON displays
This is Event2 ON
Repeat steps above to set up to seven events.
Recommended you make chart of your on-off times before starting to avoid conflicts in programming.
When programming is finished, press MODE button until automatic displays.
To override programming, press MODE button until lights come on.
For random operation, press MODE button until RDM displays
Dec 02, 2010 | Woods Outdoor 7 Day Digital Two Outlet...
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
I have a IIIWoods timer #59203WV and have trouble programming it to turn on and off exterior lights. Thanks for your response.
Manual:
http://waterheatertimer.org/pdf/Woods-59203.pdf
59203 plug-in timer: your outdoor lights have to plug into side of timer.
If you want a timer to replace outdoor light switch: buy in-wall timer Aube T1032 or Lowes sells Utilitec 0192773.
http://waterheatertimer.org/Programmable.html#Aube
Add a comment for more help with in-wall.
Here are instructions for 59203 plug-in timer:
Plug in the timer until battery is charged.
Unplug timer so you can program easily.
Press R reset button with paper clip to clear.
Set the time of day:
Press and hold clock button
Press hour button until current hour shows
Press minute button until current minute shows
Press day button until current day shows.
Program review:
Write out ON-off schedule showing hours minutes and days
For example: timer turns ON 6:00 pm all days of week.
Timer turns OFF 1:00 am all days of week.
First step: Set program1 ON > hour, minute, and day.
Next step: Set program1 OFF > hour, minute, and day
If needed, go to next step: Set program2 ON > hour, minute, and day
Next: Set program2 OFF > hour, minute, and day
How to program timer for ON at 6:00 pm and OFF at 1:00 am all days of week:
Step 1: Press PROGRAM button until display shows 1 ON (this is program1 ON)
Press hour button until 6 pm shows
Press minute button until :00 shows
Press day button until all days of week show (MO TU WE TH FR SA SU)
Step 2: Press PROGRAM button until display shows 1 OFF (this is program1 OFF)
Press hour button until 1 am shows
If you want to set another program, you will repeat same steps for program2
Press PROGRAM button until display shows 2 ON
If you are done programming, press clock button
Press ON/AUTO/OFF button until AUTO displays
Nov 13, 2010 | Woods INDUSTRIES 83660 OUTDOOR SECURITY...
Hardware & Accessories Logo
29 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
